ill.die.trying Posted April 28, 2009 Report Share Posted April 28, 2009 Would someone mind seeing if this is correct? TIA which one? 1.) is there a day and a night for the 3d car??? 2.) I've seen mention that you can modify the tilt angle of the 3d map. Can you go as far as ground level as if you were looking at the car from behind? TIA 1)no 2)yes Quote Link to post Share on other sites
gremlin190 Posted April 28, 2009 Report Share Posted April 28, 2009 Man, You are way too fast. I had problems getting my file to upload. Must be my newbie period are something. Check my previous post and it should have a link to the files now. Edit: I'm not sure if I did the background with the alpha channel properly. My first photochop Quote Link to post Share on other sites
ill.die.trying Posted April 28, 2009 Report Share Posted April 28, 2009 Man, You are way too fast. I had problems getting my file to upload. Must be my newbie period are something. Check my previous post and it should have a link to the files now. Edit: I'm not sure if I did the background with the alpha channel properly. My first photochop looks good, try it out then see if you had the alpha channels set, Quote Link to post Share on other sites
LonestarROB Posted April 28, 2009 Report Share Posted April 28, 2009 Looks good, klanbo. I think i'll give this a try soon. Need to find a good image of an F-150 first. Quote Link to post Share on other sites
gremlin190 Posted April 28, 2009 Report Share Posted April 28, 2009 Man, You are way too fast. I had problems getting my file to upload. Must be my newbie period are something. Check my previous post and it should have a link to the files now. Edit: I'm not sure if I did the background with the alpha channel properly. My first photochop looks good, try it out then see if you had the alpha channels set, It worked , but I have a white background.... I put the image on a tranlucent background. Also, I had to insert the files into my good data.zip. If I used one I let windows create then the unit would give me a windows error and then reboot after about 2 minutes. Is there a write up on how to properly make a data.zip file??? Now How do I get rid of the white background??? Also can I make the car a tad smaller? Do I have to do it photshop are can I edit the data.zip Quote Link to post Share on other sites
ill.die.trying Posted April 28, 2009 Report Share Posted April 28, 2009 Man, You are way too fast. I had problems getting my file to upload. Must be my newbie period are something. Check my previous post and it should have a link to the files now. Edit: I'm not sure if I did the background with the alpha channel properly. My first photochop looks good, try it out then see if you had the alpha channels set, It worked , but I have a white background.... I put the image on a tranlucent background. Also, I had to insert the files into my good data.zip. If I used one I let windows create then the unit would give me a windows error and then reboot after about 2 minutes. Is there a write up on how to properly make a data.zip file??? Now How do I get rid of the white background??? Also can I make the car a tad smaller? Do I have to do it photshop are can I edit the data.zip to get rid of the white background, using photoshop, click the parts of the image that you don't want to show up then select inverse and then go to channels tab and add alpha mask, Quote Link to post Share on other sites
aharper Posted April 28, 2009 Report Share Posted April 28, 2009 I've had some challenges getting this going and have checked my code over and over. I'm assuming that I have a bad .bmp file and am hoping that someone can help me make one the right way. Attached is a copy of my truck (two images in a .zip file, both 3d) from the back that I'd like to use for the 3d car, can someone help me make an image??? Thanks!!!! Quote Link to post Share on other sites
gremlin190 Posted April 28, 2009 Report Share Posted April 28, 2009 I got it!!! I'm not sure why this worked, but I selected the car and then on then selected the alpha color channel. I then cut the car out using ctrl-x which turned everything that was around the car black. Saved it and put it in and bam all was good. Quote Link to post Share on other sites
jelacf Posted April 28, 2009 Report Share Posted April 28, 2009 Man, You are way too fast. I had problems getting my file to upload. Must be my newbie period are something. Check my previous post and it should have a link to the files now. Edit: I'm not sure if I did the background with the alpha channel properly. My first photochop looks good, try it out then see if you had the alpha channels set, hello idt ,please can you post your data with cars replacing the arrow or if it is not an inconvenience ,tell me what I have to replace in your data, I have tried per days to change the arrow but this it is for intelligent persons not for idiots as me. Thank you Quote Link to post Share on other sites
ill.die.trying Posted April 28, 2009 Report Share Posted April 28, 2009 Man, You are way too fast. I had problems getting my file to upload. Must be my newbie period are something. Check my previous post and it should have a link to the files now. Edit: I'm not sure if I did the background with the alpha channel properly. My first photochop looks good, try it out then see if you had the alpha channels set, hello idt ,please can you post your data with cars replacing the arrow or if it is not an inconvenience ,tell me what I have to replace in your data, I have tried per days to change the arrow but this it is for intelligent persons not for idiots as me. Thank you aer you reffering to 2d cars? not sure what you ae asking for, also, i'm not intelligent, i just read a lot and try a lot, Quote Link to post Share on other sites
jelacf Posted April 28, 2009 Report Share Posted April 28, 2009 idt believe me that I have read and tried to do it, but cannot do it, I refer to 3d car Thank you Quote Link to post Share on other sites
ill.die.trying Posted April 28, 2009 Report Share Posted April 28, 2009 idt believe me that I have read and tried to do it, but cannot do it, I refer to 3d carThank you here's the link to the process http://avic411.com/forum/viewtopic.php?f=34&t=17490&start=45#p116696, personally i don't like the BMP pasted on the top of the arrow , i don't know if anyone has encounterd slow drawing time of the map and lagging issue when i used a bmp for the 3D vieew, Quote Link to post Share on other sites
LonestarROB Posted April 29, 2009 Report Share Posted April 29, 2009 So are you a 350 owner too? or just fancy something different to the boring triangle? doh sorry, missed this post earlier. Not quite a 350, its a 150 . F-150. Yea just trying to replace the boring arrow. I tried it once but the image wouldnt appear. Not sure I understand the hole alpha mask/layer stuff. Quote Link to post Share on other sites
aharper Posted May 2, 2009 Report Share Posted May 2, 2009 Is there anybody who can double check my work (see a couple posts up). I tried creating a new .bmp file thinking that the file may be corrupt and wasn't able to make any progress. I then tried Steph's .bmp file and had the same problem... "System startup in progress. Please wait." Several minutes later the system reboots. Thanks for the help!!! Quote Link to post Share on other sites
aharper Posted May 2, 2009 Report Share Posted May 2, 2009 woa... got it! sheesh, only took a couple weeks! Quote Link to post Share on other sites
Join the conversation
