JH315 Posted September 1, 2008 Report Share Posted September 1, 2008 Anyone have a step by step on how to keep this connected to the 700BT, or am I flat out screwed until I change phones? I've seen the other posts, but everyone seems to have a different way, and they're inconsistent. Anyone have a tried and true, step by step. Thanks in advance Quote Link to post Share on other sites
OneFast1 Posted September 2, 2008 Report Share Posted September 2, 2008 Anyone have a step by step on how to keep this connected to the 700BT, or am I flat out screwed until I change phones? I've seen the other posts, but everyone seems to have a different way, and they're inconsistent. Anyone have a tried and true, step by step. Thanks in advance So you get it connected and it disconnects? Or you can't pair it at all? Let's say you get it connected and it quits, go into the "Properties" of the selected bluetooth device on your BB, mine is "Pioneer Nav". Now be sure you have "Trusted" set to yes. you can leave Encryption on, also when you initailly connect , you have a choice to reconnect and not ask you again, make a choice there. Now maybe it connects and then disconnects, check your address book and see if you have a bunch of duplicate entries, or maybe you have more than 300. I think the limit of entries is 300, you'll have to check on that. Other than that the instructions in the manual are pretty much right on. Quote Link to post Share on other sites
lemonhead Posted September 3, 2008 Report Share Posted September 3, 2008 I wish it was that easy, its not. I will connect fine...and then randomly it will disconnect for 10-15 seconds then reconnect for a while, then wash rinse and repeat. Luckily, it does stay on for a good 15-20 minutes at a time. Quote Link to post Share on other sites
terel104 Posted September 4, 2008 Report Share Posted September 4, 2008 YEa... unfortunally my 8830 did the same thing. Btu my curve .. my chocolate worked alot better! Quote Link to post Share on other sites
ICEMAN 316 Posted October 21, 2008 Report Share Posted October 21, 2008 yup my Sprint BB 8830 has the same problem..Anyone find a fix yet? Quote Link to post Share on other sites
WidowMaker Posted October 21, 2008 Report Share Posted October 21, 2008 had that problem with my curve... connect to the headunit via the bluetooth setup menu in the phone... works like a champ that way if i connect thru the deck, it disconnects constantly... Quote Link to post Share on other sites
ICEMAN 316 Posted October 21, 2008 Report Share Posted October 21, 2008 Cool i'll try that later.. Thanks Quote Link to post Share on other sites
ICEMAN 316 Posted October 23, 2008 Report Share Posted October 23, 2008 Tried it and didn't work.. anybody else have suggestions? Quote Link to post Share on other sites
lemonhead Posted October 23, 2008 Report Share Posted October 23, 2008 Tried it and didn't work.. anybody else have suggestions? Nothing works...they keep saying the new updates fixes things with BB phones. I am actually pretty confident it will. Hang tight. Quote Link to post Share on other sites
alexstjo Posted October 25, 2008 Report Share Posted October 25, 2008 I just got my radio and have the same problem. I keeps losing the connection after about 10 -15 minutes. I called Pioneer CS and they told me to go to phonescoop.com and download some software, they didn't know what it was called! But the pioneer CS said that BB's bluetooth is different and will not work. as well as any windows phones. I am thinking about forwarding my calls to a phone that will work but I don't really want to pay 10 cents per min. Quote Link to post Share on other sites
champagnek Posted November 19, 2008 Report Share Posted November 19, 2008 On some other posts I have found a reccomendation that I tried and it worked on my 8130 and the wife's Curve. The directions are as follows: 1. Go into your address book and assign a category to all contacts of either Business or personal. 2. On your blackberry Goto Options --> Bluetooth --> Optionsand change Address Book Transfer: to Selected categories only and change Categories: by selecting Business and Personal. 3. Save changes This works great and I no longer disconnect. Step 1 appears only to be necessary to transfer your contacts. Just doing steps 2 and 3 will allow you to stop disconnecting. Good luck all I hope this helps you as much as it has for me. Quote Link to post Share on other sites
alexstjo Posted November 19, 2008 Report Share Posted November 19, 2008 In your step #1. Do you mean the address book in my outlook? Not sure which address book you mean. thanks On some other posts I have found a reccomendation that I tried and it worked on my 8130 and the wife's Curve. The directions are as follows: 1. Go into your address book and assign a category to all contacts of either Business or personal. 2. On your blackberry Goto Options --> Bluetooth --> Optionsand change Address Book Transfer: to Selected categories only and change Categories: by selecting Business and Personal. 3. Save changes This works great and I no longer disconnect. Step 1 appears only to be necessary to transfer your contacts. Just doing steps 2 and 3 will allow you to stop disconnecting. Good luck all I hope this helps you as much as it has for me. Quote Link to post Share on other sites
champagnek Posted November 21, 2008 Report Share Posted November 21, 2008 I was referring to the address book(Contacts) on my blackberry. When you edit a contact one of the fields available is categories down below birthday and anniversary. I don't use outlook so I'm not sure if that is a field you can transfer from outlook. Possibly an outlook user can provide some insight. Hope that helps clarify. Quote Link to post Share on other sites
alexstjo Posted November 21, 2008 Report Share Posted November 21, 2008 thanks I tried it in Outlook and it seemed to work. THANKS for your help Quote Link to post Share on other sites
