barryg Posted October 26, 2008 Report Share Posted October 26, 2008 I recently bought the new Avic Z3 and it will not learn the route I travel no matter what I do. Ieven call Pioneer and they told me to reset the unit and disconnect the speed pulse wire and nothing happened The Avic Z1 I gave to my brother was perfect. has anyone experience this problem and can you tell me what to do. thanks barryg Quote Link to post Share on other sites
bur1196 Posted October 26, 2008 Report Share Posted October 26, 2008 If I am correct, make sure that the auto learning function is enabled through the menu... Quote Link to post Share on other sites
defjux921 Posted October 27, 2008 Report Share Posted October 27, 2008 what exactly does the learning feature do? does it just remember that you take a different route then it thinks you should take, and then route you that way? why use navi if its a route you take all the time? im confused... Quote Link to post Share on other sites
djmixmac Posted October 27, 2008 Report Share Posted October 27, 2008 This feature works great for me. I have multiple ways I can take but I usually take a particular road. So whenever I input an address for navi guidance that goes through that area, it chooses that route in particular. You should check to see if that option is turned ON in your settings menu. Quote Link to post Share on other sites
barryg Posted October 28, 2008 Author Report Share Posted October 28, 2008 Hi Avic Nation All of the above you suggested was already done even before I call Pioneer and they asked that Question and told me to reset the the unit. Quote Link to post Share on other sites
defjux921 Posted October 28, 2008 Report Share Posted October 28, 2008 This feature works great for me. I have multiple ways I can take but I usually take a particular road. So whenever I input an address for navi guidance that goes through that area, it chooses that route in particular. You should check to see if that option is turned ON in your settings menu. where in the menu is this? Quote Link to post Share on other sites
