Yettavr6 Posted October 29, 2008 Report Share Posted October 29, 2008 I was reading through some of the common and unresolved issues threads and didn't see this one mentioned, so here goes: On only one area of the screen (upper mid right), it keeps registering multiple screen presses it seems. This is where the P. CH < > buttons are on HD radio, and where the Category < > buttons are on XM. If i try using these buttons, it constantly will register 2, 3, sometimes as much as 5 presses. Only about 25% of the time will it only register 1 press. This hasn't happened with any other function on the radio, just with these buttons which happen to be on the same part of the screen. Anyone else having this issue? Do i just have a defective screen? Quote Link to post Share on other sites
aliwalnuts Posted May 15, 2009 Report Share Posted May 15, 2009 I just purchased and had the F700BT installed and am also receiving this problem. My unit came with the 2.0 software already installed as well. Does anyone know what is causing this problem? Quote Link to post Share on other sites
w4rh4wk Posted May 15, 2009 Report Share Posted May 15, 2009 the same thing started happening to me once the weather started getting warmer. I noticed (on mine at least) it isnt do "multiple screen presses" rather it thinks you are holding your finger down on the screen. I've found if i press the screen and release slowly, for the most part it acts normally. But i know what you mean, it acts like you are do "multiple screen presses". You can also try recalibrating your screen too. Quote Link to post Share on other sites
aliwalnuts Posted May 15, 2009 Report Share Posted May 15, 2009 I've tried recalibrating and it hasn't helped the situation. I will try what you suggested with slowly releasing my finger from the screen. Hopefully it works. Quote Link to post Share on other sites
Yettavr6 Posted May 15, 2009 Author Report Share Posted May 15, 2009 Funny, i was also thinking mine got much worse since the weather warmed up. At least I know its not my imagination, although I guess that also means it is a defect in the screen and not something that can be fixed with software Quote Link to post Share on other sites
mhejl Posted May 15, 2009 Report Share Posted May 15, 2009 Another known bug. Happens with my P10 HD radio, too. Mine has even gotten stuck in an infinite loop requiring a reboot. Quote Link to post Share on other sites
Yettavr6 Posted May 15, 2009 Author Report Share Posted May 15, 2009 Ahh yes, I've had that too. Only once or twice i think, but I remember someone was in the car with me and it was pretty embarrasing. Quote Link to post Share on other sites
