iaf_22 Posted November 3, 2008 Report Share Posted November 3, 2008 My problem is solved. But apparently when you pass a speedcam the sound of the radio is muted to warn you. No change on this side, compared to previous verson. When approaching a speedcam, it starts beeping (together with Radio/SD) and when driving above the speed of the speedcam, it's the sound of a dog barking. Quote Link to post Share on other sites
Segler1963 Posted November 3, 2008 Author Report Share Posted November 3, 2008 There are still a lot of bugs in 1.9 Access to the route menue through the multi information window (bottom left) is not working anymore. The button is just not responding. Speed Limit warning is still not working properly, it always warns AT the limit no matter if set to 70% or to 130%. If you route is overlaying a TMC warning the colour (green) doesn't change (to violet) at some map scales. Incoming calls still do not show with Contact Name (may be fixed with the BT update) The navi voice is just not able to speak German numbers correct 480 turns into 48, 840 into 84. Just a bad translation but sometimes confusing if you don't look at the screen what is really meant. I'm sure there is more Good night Jörg Quote Link to post Share on other sites
Join the conversation
