grcplaya Posted September 14, 2006 Report Share Posted September 14, 2006 anybody got a solutions for this, it works and everything but the pic is very distorted. I used a kenwood camera cuz of the way it mounts. need help. grcplaya Quote Link to post Share on other sites
sl1234 Posted September 14, 2006 Report Share Posted September 14, 2006 I had an intermittent distortion problem with my pioneer camera. It turned out to be a loose connector connection at the Z1 unit. When I was checking the connections, I heard a click sound around the connection which meant that it was not secured. Now the image is perfect all the time. You can do some troubleshooting by hooking up a camcorder to the video input to the Z1 and see if the image is distorted. If it is distorted, then the Z1 has a problem. You can test the camera by hooking it up to the AUX input of the Z1 and see if it is distorted. Quote Link to post Share on other sites
DataAve Posted September 14, 2006 Report Share Posted September 14, 2006 We have "spot monitors" to do just that. You can actually use your camcorder to do same. If not, use a portable tv. Just make sure the power to the cam is good. Quote Link to post Share on other sites
grcplaya Posted September 14, 2006 Author Report Share Posted September 14, 2006 well I went an took out the Z1 to see if all the connections were secure buu then I noticed the neg. connector for the camera Rca input was not pushed in all the way on the harness so I took care off that and presto we have a better pic NOw :D remember check the All connections before you put all back in!! make sure they are in place thanks guys grcplaya Quote Link to post Share on other sites
