chrisc2 Posted November 6, 2008 Report Share Posted November 6, 2008 Hey Guys, I have a Z1 and the reverse cam works perfectly when I'm backing up -- with the car in reverse but when I go to the Reverse Cam/Map mode, I get 2/3 of a black screen and 1/3 map. Does anyone know what's wrong? Thanks in advance! Chris. Quote Link to post Share on other sites
offroaderf150 Posted November 6, 2008 Report Share Posted November 6, 2008 the camera power wire is wired to the reverse light instead of an accessory source. so the camera only turns on when you go into reverse. you need to wire it up to the accessory power that your radio gets to turn on. Quote Link to post Share on other sites
djmixmac Posted November 6, 2008 Report Share Posted November 6, 2008 I purposely powered my rearview camera to my reverse lights. I heard of some cameras life span drastically reduce due the fact that they were always powered on while driving. I invested some $$ in a nice backup camera and I didn't want to have it die prematurely. Quote Link to post Share on other sites
chrisc2 Posted November 6, 2008 Author Report Share Posted November 6, 2008 the camera power wire is wired to the reverse light instead of an accessory source. so the camera only turns on when you go into reverse. you need to wire it up to the accessory power that your radio gets to turn on. Cool thanks.. Is this easy to fix? I have very little knowledge about stuff like this... Quote Link to post Share on other sites
offroaderf150 Posted November 6, 2008 Report Share Posted November 6, 2008 yeah it is easy to fix. you need to find out where the power lead to the camera is and run the new accessory wire to it. so pull out the radio, tag a wire to the red wire on the z and run it all the way to the back up camera. find where the camera's power wire is tapped into and disconnect it and connect the new wire run from the radio to the camera's power wire. Quote Link to post Share on other sites
03_PSD Posted June 7, 2012 Report Share Posted June 7, 2012 Thank you search button!! This is what my z is doing, now I know how to fix it. Quote Link to post Share on other sites
