fanito Posted September 16, 2006 Report Share Posted September 16, 2006 I am trying to put the wires together but I'm not sure how to sucessfully accomplish this. I attached a pic with one of my main concerns. Basically is just matched them and ground 2 here and 1 in Connector 2, right? 1. I have a ground in my harness, should I use that one? Or should I ground each one individually or tap the one in the AVIC harness with the car harness and ground that longer cable. 2. The green (parking brake ground) should be grounded on it's own or can be tapped into so I can ground 3 things using 1 wire. Any other suggestions (or help) would be highly appreciate . Thanks Quote Link to post Share on other sites
cntrylvr79 Posted September 16, 2006 Report Share Posted September 16, 2006 You can connect all 3 wires to the ground wire in the vw harness there. As far as connections go, you have a couple options. Solder and tape, twist and tape, or butt connectors. If you go with either tape method make sure you use good quality electrical tape. Quote Link to post Share on other sites
fanito Posted September 16, 2006 Author Report Share Posted September 16, 2006 thank you! very interesting, and good call, it's for VW but actually for a benz (so I guess they are the same) I have another question (sorry... at least I put pics... :) To create a ground cable my "connector 2" lack of a metallic connection at the end. I wish I could be more specific but it doesn't make a lot of sense to connect a ground to plastic. That really is the same as nothing... but honestly I really don't know and the best of all I have faith in you guys :D Quote Link to post Share on other sites
cntrylvr79 Posted September 16, 2006 Report Share Posted September 16, 2006 What you have to do is remove one of the unused pins from the power harness for instance and insert it into that empty slot. By the way since you're putting this into a benz, you'll have to hook the yellow wire from the avic harness to the red wire in the vw harness and the red wire of the avic harness to the yellow wire of the vw harness. When you use the vw harness in benz's or beamers you have to swap those 2 wires otherwise youlose presets and stuff. Quote Link to post Share on other sites
Lhaff Posted September 16, 2006 Report Share Posted September 16, 2006 One other thing you might consider doing, to make it all look really nice and professional when you're done, is get yourself some heat shrink tubing and putting that on each wire after you've connected them. Heck, I dunno, maybe you're already on top of that! :) Cheers! Quote Link to post Share on other sites
fanito Posted September 16, 2006 Author Report Share Posted September 16, 2006 [quote name="cntrylvr79"]What you have to do is remove one of the unused pins from the power harness for instance and insert it into that empty slot. By the way since you're putting this into a benz, you'll have to hook the yellow wire from the avic harness to the red wire in the vw harness and the red wire of the avic harness to the yellow wire of the vw harness. When you use the vw harness in benz's or beamers you have to swap those 2 wires otherwise youlose presets and stuff.[/quote] I can't thank you enough Quote Link to post Share on other sites
jimmy303 Posted September 16, 2006 Report Share Posted September 16, 2006 Nice save, cntrylvr! I'm impressed you remembered the wire switch.... Quote Link to post Share on other sites
fanito Posted September 16, 2006 Author Report Share Posted September 16, 2006 [quote]By the way since you're putting this into a benz, you'll have to hook the yellow wire from the avic harness to the red wire in the vw harness and the red wire of the avic harness to the yellow wire of the vw harness. When you use the vw harness in benz's or beamers you have to swap those 2 wires otherwise youlose presets and stuff.[/quote] Does it matter that the yellow has the 10A fuse?[/code] Quote Link to post Share on other sites
cntrylvr79 Posted September 16, 2006 Report Share Posted September 16, 2006 No it doesn't. That's the fuse for the z1. Like I said just make sure you flop the red and yellow wires and you'll be good. Jimmy303 - Yeah, after troubleshooting many other installers and forget or did know that, it's permanantly engrained in what's left of my brain. Quote Link to post Share on other sites
fanito Posted September 17, 2006 Author Report Share Posted September 17, 2006 so, I wired up everything and the unit did not power up... :( ... I'm I doing something wrong? is there an on/off switch that I'm not aware of? This is sooooo sad :'( Quote Link to post Share on other sites
cntrylvr79 Posted September 17, 2006 Report Share Posted September 17, 2006 What year is the benz? Quote Link to post Share on other sites
fanito Posted September 17, 2006 Author Report Share Posted September 17, 2006 2002 this is how I wired it and some pics inside... So, I finally got it to work. The yellow one and the red one are just decorative in the metra harness. I found out that the harness lacks of a hot wire (maybe is in the incorrect position), that sucked. I had to ran a wire from the cigarrette adapter to the harness, what a pain in the butt. So I finally got everything together, now I have left to do the XM wiring... I am about to give up... (I think I can tap the newly created connection, right?) Oh boy, everything is a pain... not that simple, not that simple... Does anyone knows what wires do I need to hookup the XM? thanks Quote Link to post Share on other sites
cntrylvr79 Posted September 18, 2006 Report Share Posted September 18, 2006 That thick red?white wire back there should read as a constant unless there"s a blown fuse somethwere in the car. But I guess that doesn't matter anymore since you ran a new one. Such is life any pics of the z1 actually in the car? Quote Link to post Share on other sites
fanito Posted September 18, 2006 Author Report Share Posted September 18, 2006 cough. cough... maybe there was also a blown fuse... hehehehe, I did change it but no love so I had to do it straight. Can I tap the newley connection to get power for my XM from there? Is it possible or do I have to take the long way from the battery (man that's a long wire) Quote Link to post Share on other sites
cntrylvr79 Posted September 18, 2006 Report Share Posted September 18, 2006 No, you can tap power for the xm right behind the radio as well. Quote Link to post Share on other sites
