blackdog69 Posted November 9, 2008 Report Share Posted November 9, 2008 I had this posted in General, but I think this forum is better suited: 700bt Is there a way to get rid of the second turn dialog box in the upper left top of screen, which is confusing, but keep the dialog box (multi infox box) at bottom left of screen that has 3 lines of information? It seems like they both come and go together when the full screen checkbox is checked? I want the bottom left box only. Quote Link to post Share on other sites
brink094 Posted November 10, 2008 Report Share Posted November 10, 2008 It is possible to get rid of just the second turn box but you have to mod your Avic, read the faq in this subforum on how to do this. (getting into testmode etc) The file you need to mod is the data.zip/ui_pioneer/800_480/ui/navigatemap_800_480.ui file, the file where most of the mods in this forum happen. You will find the secondary turn box inside the ui_NavigateMapRouteNavigation layer. You will need to disable 5 lines in total: - the sprSecCorner sprite, this is the blue background - two sprites named xxx, the secondary_direction_icon and secondary_exit_icon, these are the little icons at the left. - two text lines named xxx, the secondary_distance_to_manuver number and unit lines. If you disable these five lines by placing a ';' in front of them the second turn box will be gone. If this sounds to complicated, I suggest you just live with the second turn box Quote Link to post Share on other sites
