armangti Posted November 13, 2008 Report Share Posted November 13, 2008 Hey guys, I just got my Avic D3 that i purchased off ebay. I have a 12V battery in my room and i connect the Red+Yellow Wire to the Positive Side, and i put the black wire to the Ground (-) negative side. The fan on the D3 comes on and the display or lights dont come on either. I just want to test it on my 12V battery before i buy the dash kit and everything. I want to know everythings functioning before i install it because if it isnt i can just return it to the seller. Also, i tried connect the Illuminator to the (+) and that didnt help. The fan just comes on but nothing. Any ideas? What should i do, please help!! Quote Link to post Share on other sites
madsonp Posted November 13, 2008 Report Share Posted November 13, 2008 Sounds like it's toast to me. Not that I think it'll help, but did you try pushing the reset button ? I'd say you're going to end up sending it back. Quote Link to post Share on other sites
CamelTowing Posted November 13, 2008 Report Share Posted November 13, 2008 You sure that battery is giving it a full 12 volts? Quote Link to post Share on other sites
armangti Posted November 13, 2008 Author Report Share Posted November 13, 2008 Yes, it is giving full 12 volts. I even tried the battery on my car. Where is the reset button located? Quote Link to post Share on other sites
Julius Posted November 13, 2008 Report Share Posted November 13, 2008 Did you check your fuse? Quote Link to post Share on other sites
armangti Posted November 13, 2008 Author Report Share Posted November 13, 2008 the fuse is working fine. Quote Link to post Share on other sites
Julius Posted November 13, 2008 Report Share Posted November 13, 2008 I believe it needs to be returned.The illumination wire will only darken the screen when 12 volts is applied. Quote Link to post Share on other sites
madsonp Posted November 14, 2008 Report Share Posted November 14, 2008 Yes, it is giving full 12 volts. I even tried the battery on my car. Where is the reset button located? Small hole up by the menu and map buttons Quote Link to post Share on other sites
armangti Posted November 14, 2008 Author Report Share Posted November 14, 2008 i tried the reset button, nothing changed besides the fan. The fan runs like pulsing _/\_/\_....when i press the reset and hold it the fan will run steadily normal. I bought this for $240 and do you think i should return it or get it fixed by my dad(electrical engineer) he fixes car stereos and does electrical work for a living. Quote Link to post Share on other sites
Julius Posted November 14, 2008 Report Share Posted November 14, 2008 Let your dad look at it,if it's a simple fix for him then by all means let him do it.If the parts are costly and the labor is too involved then send it back.Remember your warranty period,don't let it expire. Quote Link to post Share on other sites
armangti Posted November 15, 2008 Author Report Share Posted November 15, 2008 no luck, we opened the top and couldnt see anything. I'd rather return it because if we open it and if its something not fixable..They will probably know that i opened the unit and not exchange/return it at all. Quote Link to post Share on other sites
Julius Posted November 15, 2008 Report Share Posted November 15, 2008 Next time get your D3 off of this site, they're selling them all the time. I bought my Eclipse Nav. from here about a year ago and had no problems. Go into the classified and look around. Good-Luck ! P.S. Let us know how your return go ! Quote Link to post Share on other sites
