nuflat Posted November 13, 2008 Report Share Posted November 13, 2008 I am running into an issue with the voice guidance where it is constantly telling me to keep right. When I am on the freeway it is telling me to keep right and when I am on a service road trying to enter a freeway it would say something like "keep right onto highway" even though I am supposed to go left. Also I couldn't find it anywhere but is there an option to limit the amount of prompts from the voice guidance? Any ideas? Thanks Quote Link to post Share on other sites
freakshow999 Posted November 19, 2008 Report Share Posted November 19, 2008 I encountered the exact same problem today. Voice kept saying to keep right when if anything it should have been telling me to keep left to stay on the highway. I wonder if this would be fixed by using IGo8? Anyone got any insight on this one? Quote Link to post Share on other sites
BorisM Posted November 19, 2008 Report Share Posted November 19, 2008 You do realise that the unit is using iGO 8 currently, just with a bit different TTS setup than normal (Nuance as opposed to Loquendo). This being said, you can open command.csv file in the voice configuration zip and chanhge it to say pretty much anything... Quote Link to post Share on other sites
nuflat Posted November 19, 2008 Author Report Share Posted November 19, 2008 I also noticed this morning on the way to work that it was telling me to exit onto the freeway! Quote Link to post Share on other sites
MR. WOMO Posted November 19, 2008 Report Share Posted November 19, 2008 nuflat - I don't know why, but this popped into my head while reading your last post: WHY would you have your navigation set to give you directions to go to work? Quote Link to post Share on other sites
nuflat Posted November 19, 2008 Author Report Share Posted November 19, 2008 Generally, I use it for traffic purposes. My D3 was pretty good at rerouting me with the NavTraffic and I am testing the waters with this unit. Most of the time I don't have a problem finding my way to work! Quote Link to post Share on other sites
nuflat Posted November 19, 2008 Author Report Share Posted November 19, 2008 You do realise that the unit is using iGO 8 currently, just with a bit different TTS setup than normal (Nuance as opposed to Loquendo). This being said, you can open command.csv file in the voice configuration zip and chanhge it to say pretty much anything... As far as that goes what is it using for a marker to trigger that particular command in the csv file? I see some numbers under Iconid but I am not sure how that works. I guess I will need to experiment. Quote Link to post Share on other sites
BorisM Posted November 19, 2008 Report Share Posted November 19, 2008 It seems that vocal/iconid corresponds to the direction indicators displayed on screen (i.e. 0 is for "straight" arrow, even if it is used in what the unit considers different situations -- continuing straight, continuing on the highway, etc.). I imagine that a change in _current_ navigation advice triggers first notice, and then cit checks conditions in distance column to repeat and/or change directions (turn in XXX miles, prepare to turn, etc. Quote Link to post Share on other sites
