brogan2424 Posted November 21, 2008 Report Share Posted November 21, 2008 One thing I just realized is that I'm getting zero AM reception...not bad, not could be better, nothing...I had it w/my stock stereo & I had it when my D3 was installed in my other vehicle...does anyone know off hand what it could be?? Quote Link to post Share on other sites
CamelTowing Posted November 21, 2008 Report Share Posted November 21, 2008 Does your car have a powered antenna that needs to be hooked up to the D3 to turn on? Quote Link to post Share on other sites
brogan2424 Posted November 21, 2008 Author Report Share Posted November 21, 2008 Does your car have a powered antenna that needs to be hooked up to the D3 to turn on? I'm not sure...I have a 2006 Lexus IS250...there's no visible antenna, it's internal...don't know if it's powered or not...I'll do some research & see if I can find out... Quote Link to post Share on other sites
risestar Posted November 22, 2008 Report Share Posted November 22, 2008 check the antenna connection at the back of the unit as well as the connection on any antenna adapter you have from the factory antenna cable Quote Link to post Share on other sites
wpageabc Posted November 26, 2008 Report Share Posted November 26, 2008 Are you getting FM signal? Quote Link to post Share on other sites
brogan2424 Posted November 27, 2008 Author Report Share Posted November 27, 2008 Are you getting FM signal? Yes, I'm getting a perfect FM signal & zero AM at the moment...The shop that installed my D3 looked at all the connections & said evrything is correct...I'm at a loss at the moment on what could be wrong... Quote Link to post Share on other sites
Sprawl Posted December 5, 2008 Report Share Posted December 5, 2008 i'm getting the same issue. I'm in a 2006 vibe, so it's a standard antenna that stays up all the time. I've got near perfect if not perfect FM reception, but AM is not there. it's quiet at best, and crackly if it gets anything. i have to crank the volume to 20 to just hear it Quote Link to post Share on other sites
