Cmacrae Posted January 3, 2009 Report Share Posted January 3, 2009 Installed in a 2002 jetta but doesn't shut off when car is powered off and key is out. Any ideas? Quote Link to post Share on other sites
M4T VW Posted January 3, 2009 Report Share Posted January 3, 2009 See here... http://www.avic411.com/forum/viewtopic.php?t=20542 Does a 2002 Jetta have an ISO connection or is it quadlock? Its becuase you have taken the factory radio out and that has the can-bus built in. The Pioneer is getting a live feed from the yellow wire and red wire. The red wire is the ACC switch. You need to tap into the ignition switch or the way i did it was find a pin on the VW harness that the ignition controls and use that. The better way would be to install a can-bus adapter and this will give you switched ignition as well as speed sensor, reverse and illumniation. Let me know what conection you have Quote Link to post Share on other sites
Cmacrae Posted January 3, 2009 Author Report Share Posted January 3, 2009 This worked! Thank you!!! Quote Link to post Share on other sites
