2fasst Posted January 11, 2009 Report Share Posted January 11, 2009 I plan on running two amps, how should I run the remote activation turn-on wire? Should I run one wire from the head unit, then split into two (one for each amp)? Or should I run a jumper wire from the first amp to the second amp? thoughts guys? Quote Link to post Share on other sites
madsonp Posted January 11, 2009 Report Share Posted January 11, 2009 run a jumper wire from the first amp to the second amp Quote Link to post Share on other sites
joegr Posted January 11, 2009 Report Share Posted January 11, 2009 Either way should work as well as the other. Quote Link to post Share on other sites
madsonp Posted January 11, 2009 Report Share Posted January 11, 2009 I found running the jumper makes for a little cleaner install, but like joegr said, either way will work. Quote Link to post Share on other sites
avic4me Posted January 11, 2009 Report Share Posted January 11, 2009 i know at the shop i used to work at we did jumper wires it just looked cleaner to us and one less wire to deal with until you get to the amps. Quote Link to post Share on other sites
2fasst Posted January 12, 2009 Author Report Share Posted January 12, 2009 thanks guys..I appreciate your input and time to help out newbie installers like myself! Quote Link to post Share on other sites
