lsunv2 Posted January 26, 2009 Author Report Share Posted January 26, 2009 i just got my unit in today and want to start the install tomorrow. im using the factory amps and need to knwo how to wire this. any help is appreciated Quote Link to post Share on other sites
watkch01 Posted January 26, 2009 Report Share Posted January 26, 2009 The wiring diagrams that come with the unit are a good place to start. Quote Link to post Share on other sites
joegr Posted January 27, 2009 Report Share Posted January 27, 2009 The wiring diagrams that come with the unit are a good place to start. They're no help when it comes to hooking this up to the LS. The harness you bought almost certainly is wrong for this. The LS with factory navigation is wired completely differently from LS's without it. The 24 pin connector would normally have the four speaker connections, but with nav, it does not. The factory wiring diagrams that I have do not give the connections/pin-outs for the navigation headunit. (Oddly enough, it does give them for the trunk mounted part.) When you do find the remote amp turn-on wires (there will be two, one for the subwoofers, and one for the eight speakers), you need to connect a 1000 ohm resistor between them and the remote turn-on from the AVIC. This will keep them from popping at startup. Quote Link to post Share on other sites
lsunv2 Posted January 29, 2009 Author Report Share Posted January 29, 2009 im just gonna take it to the pros, thanks for everyones help Quote Link to post Share on other sites
Join the conversation
