basstoy Posted February 21, 2009 Report Share Posted February 21, 2009 if you check pacaudio.com the make a plug and play adapter for the truck that has thoes wires and the steering wheel controls. i happen to have on if your interested. You do realize that this is a Lincoln LS, a car, not a truck? The AVIC will work even better with the VSS connected. There is no reason not to on this car as the signal is easy to get to. I happen to have an 04 LS and an 06 LS, I do know what I am talking about. you think the ls is the same as the fusion? are they not the same body??? cuse I cant find my VSS anywhere.. they say that I need some sort of CANbus adapter....anyways.. let me know thanks Quote Link to post Share on other sites
joegr Posted February 21, 2009 Report Share Posted February 21, 2009 if you check pacaudio.com the make a plug and play adapter for the truck that has thoes wires and the steering wheel controls. i happen to have on if your interested. You do realize that this is a Lincoln LS, a car, not a truck? The AVIC will work even better with the VSS connected. There is no reason not to on this car as the signal is easy to get to. I happen to have an 04 LS and an 06 LS, I do know what I am talking about. you think the ls is the same as the fusion? are they not the same body??? cuse I cant find my VSS anywhere.. they say that I need some sort of CANbus adapter....anyways.. let me know thanks Sorry, I don't know anything about the Fusion. I do know that the LS is not like any other Ford. It is more like the Jaguar S series. Quote Link to post Share on other sites
lseguy1 Posted February 22, 2009 Report Share Posted February 22, 2009 Catchme and Joey...either of you have the info for the VSS wire on a 2002 V8 Lincoln LS? NO one on the LS forums knows where the VSS is for this one. My D3 was fine with no VSS but the F series is always about 100 feet off. Quote Link to post Share on other sites
joegr Posted February 23, 2009 Report Share Posted February 23, 2009 Catchme and Joey...either of you have the info for the VSS wire on a 2002 V8 Lincoln LS? NO one on the LS forums knows where the VSS is for this one. My D3 was fine with no VSS but the F series is always about 100 feet off. I don't, maybe Catchme does. The gen II LS's have two VSS signals inside the car (not counting the data carried by the CAN bus). One was for the factory (Pioneer, by the way) navigation, and the other was for the rear-parking aid. If gen I had the rear parking aid option, then you might find it there. On gen II, the two VSS signals originate at the ABS controller under the hood. Gen I might be the same. Quote Link to post Share on other sites
1loudls Posted February 23, 2009 Report Share Posted February 23, 2009 if you check pacaudio.com the make a plug and play adapter for the truck that has thoes wires and the steering wheel controls. i happen to have on if your interested. You do realize that this is a Lincoln LS, a car, not a truck? The AVIC will work even better with the VSS connected. There is no reason not to on this car as the signal is easy to get to. I happen to have an 04 LS and an 06 LS, I do know what I am talking about. you think the ls is the same as the fusion? are they not the same body??? cuse I cant find my VSS anywhere.. they say that I need some sort of CANbus adapter....anyways.. let me know thanks the Fusion and the Lincoln Zepher (or MKZ) are both built off of the mazda 6 platform, they have nothing in common with the LS. i was looking through our shop software and for a 08 fusion i found that reverse wire should be green/white stripe at the SJB (Smart Junction Box) connector E, pin 21. the SJB is under the driver side dash. the VSS wire should be brown/white stripe at the PCM, bottom plug, pin 65 or Yellow in pin 46 at the ABS module(ABS module is in front of the passanger strut tower always double check with a digtal multi-meter Quote Link to post Share on other sites
RicanRaskul Posted February 25, 2009 Author Report Share Posted February 25, 2009 Finally installed my avic-f900bt to my LS the wire were on point! I also installed the PAC Stering Wheel Interface! Works Like a charm! A special Thanks to joegr! You been a great help.....thanks! Quote Link to post Share on other sites
lseguy1 Posted February 28, 2009 Report Share Posted February 28, 2009 rican...what year LS? No luck finding the VSS in my 2002 Quote Link to post Share on other sites
Join the conversation
