JDub86 Posted March 7, 2009 Report Share Posted March 7, 2009 Thats what I did with mine in my Scion. I mounted it on the metal plate under the dash behind the gauge cluster. Quote Link to post Share on other sites
stan1000 Posted March 11, 2009 Report Share Posted March 11, 2009 I put mine right on top of the head unit under the heat vents inside the console. It works just fine. Quote Link to post Share on other sites
Fen911 Posted March 13, 2009 Report Share Posted March 13, 2009 Put mine right on top of the car on the rear. Quote Link to post Share on other sites
MaxPower Posted March 13, 2009 Report Share Posted March 13, 2009 Like others, mine's hidden in the dash, on top of the center HVAC ducts. Every now and then I check the reception, and I regularly get nine satellites showing up as green (i.e. usable signal). I'm pretty sure that's way more than the system needs for accurate navigation. Quote Link to post Share on other sites
rowold30 Posted March 16, 2009 Report Share Posted March 16, 2009 i put mine in the front of the dash as close as i could get it to the windshield on the drivers side.....and i havent had any problems yet at all Quote Link to post Share on other sites
noxguy83 Posted March 16, 2009 Report Share Posted March 16, 2009 Tint will only affect the gps signal it it is metallic. I usually install them on the front dash or under a plastic panel in the front. On my personal vehicle I ran it up to the top of the windshiled and double sided taped it the the windshield in the middle(just above the rearview mirror). This way there is nothing on top of my dash and you doent even notice its there, looks like a factory item. Works great with perfect signal. Quote Link to post Share on other sites
jin22gt Posted March 18, 2009 Author Report Share Posted March 18, 2009 Hey guys, THANKS for all your replys! Im trying to make the gps antenna discreet as possible. I was thinking about putting the antenna under the front windshield vents, but im scared I will lose reception. Im not sure if my 20% rear windshield tints are metallic or not. Is there a way to find out if my tints are metallic or not? Im going to try to stop by the tint shop if there isn't a way to find out myself. Â Thanks for your help guys. Quote Link to post Share on other sites
paQ Posted March 18, 2009 Report Share Posted March 18, 2009 how about switching your unit on with the antenna under the dash and see what happens Quote Link to post Share on other sites
jin22gt Posted March 22, 2009 Author Report Share Posted March 22, 2009 Is the antenna pad really needed? I didn't use the pad. Seems to get ok reception. Quote Link to post Share on other sites
VBLUE42 Posted March 22, 2009 Report Share Posted March 22, 2009 I have mine installed on the top of the unit. I get max signal. Quote Link to post Share on other sites
zephyrloco Posted March 22, 2009 Report Share Posted March 22, 2009 I put mine behind the radio, inside the dash. There was a metal piece that extends behind the whole dash and I just stuck mine on that and get prefect signal. Quote Link to post Share on other sites
KillaICM Posted March 22, 2009 Report Share Posted March 22, 2009 I have mine INSIDE my dash. I doubt tint is going to make a difference. Quote Link to post Share on other sites
