swankydank2001 Posted March 10, 2009 Report Share Posted March 10, 2009 Am i the only one having this problem. When i play a song from the car it does not finish out the whole song Quote Link to post Share on other sites
BlackSabbath12 Posted March 10, 2009 Report Share Posted March 10, 2009 i got the same problem with some mp3s Quote Link to post Share on other sites
Bopper Posted March 10, 2009 Report Share Posted March 10, 2009 mine's fine. Quote Link to post Share on other sites
MorningZ Posted March 11, 2009 Report Share Posted March 11, 2009 I have this happen now and then, i notice that it happens more often the more full my SD card is Playing the song(s) on my computer through an SD card reader, they are fine and play right to the end Quote Link to post Share on other sites
CalTom Posted March 11, 2009 Report Share Posted March 11, 2009 mine's fine. Jep, mine as well. Played a lot of MP3 from SD so far. Quote Link to post Share on other sites
petrocelly Posted March 13, 2009 Report Share Posted March 13, 2009 i having the same problem, i thought that my files are corrupted but they play perfectly on my PC Quote Link to post Share on other sites
ScottDoom Posted March 13, 2009 Report Share Posted March 13, 2009 I had this problem happen as well. It all seemed to be fine at first, and I actually just drove home and it was fine again. However, earlier tonight I was driving to a friend's with the GPS on, and the GPS voice kept popping up to give instructions and then my music started skipping to the next track. I just checked my music files, and the album that was skipping was recorded in VBR. I'm going to listen to another album tomorrow that's VBR as well, and then a couple of static-rate files and see if that's the problem. That was my initial guess, that the player has difficulty with VBR files. You guys might check that as well. Let me know what you get. In case you don't know, VBR is Variable Bit Rate which is a type of MP3-encoding that varies the bitrate through the song to achieve the best quality and the smallest file size. Instead of having a flat bit rate like 128, 256, or 320. So start playing some VBR albums if you have them, and then play some non-VBR albums. Quote Link to post Share on other sites
wmitch927 Posted March 13, 2009 Report Share Posted March 13, 2009 Albums??? You're showing your age Scott... Quote Link to post Share on other sites
ScottDoom Posted March 13, 2009 Report Share Posted March 13, 2009 Believe it or not, artists still release music in a collection known as an album. Here's some screenshots to show the difference between VBR and non-VBR albums. The VBR album has bitrates between 192kbps to 320kpbs listed even though they are all from the same source, while the SBR album's tracks all have 320kpbs flat. I'm going to go test now to see if only the VBR files are the ones skipping. If so, all we'll have to do is recode them to SBR and then no more skipping songs! Quote Link to post Share on other sites
pim_simons Posted March 25, 2009 Report Share Posted March 25, 2009 any update on your progress? is there really a difference in VBR and non-VBR when played on the pioneer nav? Quote Link to post Share on other sites
