jwq Posted March 26, 2009 Report Share Posted March 26, 2009 I just checked the service manual of the F900 F90, and there is a (hardware) difference between the European and US versions of the unit. The AV (Audio/Video) unit is different. For those with the manual, on page 24 you can see that the European and US versions use a diferent microcontroller.... So, it is not going to be possible to simply add RDS/TMC by means of a software update..... Quote Link to post Share on other sites
Chorca Posted March 26, 2009 Report Share Posted March 26, 2009 Ah. Wasn't aware of the different versions of the actual unit and service manual. Looks like it'd be a bit harder than suspected, guys. Quote Link to post Share on other sites
paQ Posted March 26, 2009 Report Share Posted March 26, 2009 TMC and RDS could very well be. It is the FM synth we are trying to get to run on different increments. I still do can't believe that it is impossible to have on US models. FM is FM. Within a frequency range you can take signals in (in the set increments) Furthermore US models can have RDS signals when the HD tuner is connected. Quote Link to post Share on other sites
jwq Posted March 26, 2009 Report Share Posted March 26, 2009 TMC and RDS could very well be.It is the FM synth we are trying to get to run on different increments. I still do can't believe that it is impossible to have on US models. FM is FM. Within a frequency range you can take signals in (in the set increments) Furthermore US models can have RDS signals when the HD tuner is connected. Tuner is controlled by the microcontroler I mentioned, so different increments is not going to happen Re. RDS with HD tuner, of course that works because you do not use the internal tuner but an external tuner.... Quote Link to post Share on other sites
Chorca Posted March 26, 2009 Report Share Posted March 26, 2009 Right. Well the FM tuner would most likely work fine. The TMC/RDS/MSN chip is actually on the Navi board, which is separate from the AV board, where the FM tuner lives. The AV board contains the FM tuner and an amplifier for the TMC/RDS/MSN, which is then sent up to the Navi board with a coaxial cable. Quote Link to post Share on other sites
jwq Posted March 26, 2009 Report Share Posted March 26, 2009 Right. Well the FM tuner would most likely work fine. The TMC/RDS/MSN chip is actually on the Navi board, which is separate from the AV board, where the FM tuner lives. The AV board contains the FM tuner and an amplifier for the TMC/RDS/MSN, which is then sent up to the Navi board with a coaxial cable. Yes, but the whole business is controlled by a microcontroller (IC610), which is different for the 2 versions.... (different embedded ROM programs) Quote Link to post Share on other sites
Chorca Posted March 26, 2009 Report Share Posted March 26, 2009 Ohhh.. I didn't see the two different part numbers listed for it. Possible there's different roms in there or something, then.. Quote Link to post Share on other sites
jwq Posted March 26, 2009 Report Share Posted March 26, 2009 Ohhh.. I didn't see the two different part numbers listed for it. Possible there's different roms in there or something, then.. Yep, you can also see it on page 136.... It's probably a microcontroller,with different embedded ROM programs in the US and EU versions... Quote Link to post Share on other sites
jwq Posted March 26, 2009 Report Share Posted March 26, 2009 Right. Well the FM tuner would most likely work fine. The TMC/RDS/MSN chip is actually on the Navi board, which is separate from the AV board, where the FM tuner lives. The AV board contains the FM tuner and an amplifier for the TMC/RDS/MSN, which is then sent up to the Navi board with a coaxial cable. B.t.w., just for info, again looking at the service manual, the Navi board is probably also different between the EU and US versions, see page 117 and 187.... So to summarise, there are a number of distinct hardware differences between the US and EU versions..... Quote Link to post Share on other sites
Chorca Posted March 26, 2009 Report Share Posted March 26, 2009 Yeah, if there are too many differences between the two, it'd most likely be too difficult to convert between the two versions.. Quote Link to post Share on other sites
Join the conversation
