Avic F-90bt harnesses the same as D3?
Hello
We did exactly that saturday. I had a D3 installed with bypass and I replaced it with a F-90BT with bypass also.
All the installer had to do is change the connector place for the bypass. He then reconnected it and it worked perfectly.
On thing is that the GPS connector is not the same, so we had to change the GPS antenna.
The XM and Microphone connectors are the same also.
Greetings
Labgate
