Deuceman927 Posted October 23, 2006 Report Share Posted October 23, 2006 So I got my head unit back from the repair shop, and with the upgraded software. Everything looks and works GREAT. The only problem is that the voice guidance doesn't work. I think it MAY have to do with the fact that I recently removed the stock speakers from use. I'm now using all pre-out signal. Does the voice only come out through the high level outputs ? Thanks in advance for your help :) Quote Link to post Share on other sites
SVT Amateur Posted October 23, 2006 Report Share Posted October 23, 2006 [quote name="ajpleblanc"]So I got my head unit back from the repair shop, and with the upgraded software. Everything looks and works GREAT. The only problem is that the voice guidance doesn't work. I think it MAY have to do with the fact that I recently removed the stock speakers from use. I'm now using all pre-out signal. Does the voice only come out through the high level outputs ? Thanks in advance for your help :)[/quote] I believe that is correct. I'm using speaker level and not line level outputs for my front speakers but I know that the voice guidance is only heard through the front speakers, so I'm guessing it wouldn't be heard on any of the line level outputs. Quote Link to post Share on other sites
Deuceman927 Posted October 23, 2006 Author Report Share Posted October 23, 2006 Crrrrrrrap... I thought of hooking up a single speaker for voice navigation. I'll have to check that out. Thanks for the input :) Quote Link to post Share on other sites
