Yazon Posted May 22, 2009 Report Share Posted May 22, 2009 Hey guys, So I've finally got around to installing the system - but i can't figure out what the manual says about the yellow cable. In F500BT connection guide in picture 8 they show it connected to ND-G500. Yet right there they also say to connect it to the always on 12V source. So i need to connect the yellow to ND-G500 or just to 12V directly from car battery? Quote Link to post Share on other sites
Sgthawker Posted May 23, 2009 Report Share Posted May 23, 2009 If you use the ND-G500, you can hook the F-500BT's yellow wire to the NDG's wire harness which has a y to connect it. You can also hook it separately to the 12v always hot, or use the NDG's, it is up to you. Quote Link to post Share on other sites
Yazon Posted May 23, 2009 Author Report Share Posted May 23, 2009 So the yellow from ND-G500 also always has power? If i understand you right - i should not connect direct from the battery AND yellow from ND-G500. Either one or the other, right? Thanks! Quote Link to post Share on other sites
Sgthawker Posted May 24, 2009 Report Share Posted May 24, 2009 Hook the battery hot to the ND-G500, and then use the y built into it's harness to plug in the yellow wire from the F-500BT. It is the easiest answer. Quote Link to post Share on other sites
