dragon24 Posted June 12, 2009 Report Share Posted June 12, 2009 The unit starts to boot up & when it get about 30sec's into the loading. It turs off. I checked the power fuse & the fuse on the unit itself. I also tried the reboot button on the front of the unit it self & still a no go. Unit has the hardware bypass on it. Any help would be great in this matter. 1) Checked fuses 2) Try reset button 3) Try a hard reset by holding eject and reset for 5 seconds. 4) try my ResetToOEM file from here: ftp://avic:avic-411@buckeyecollision.us ... tToOEM.zip Unit turns off in the middle of updating files. 5) Just try to do the Back-Up Camra problem.... no go with that. 6) try to reinstall version 2.0 update ' Couldn't finish update had "error code 18 maybe disk space is size full" on it. got up to 77% and stoped well i have more thing than when i started to play. The unit doesn't turn off no. I can now get into testmode but i have no clue on what to do. But does anybody know how to do a fresh install of 2.0. im working on getting the files & hopefully this will work. Quote Link to post Share on other sites
minifreezer Posted June 13, 2009 Report Share Posted June 13, 2009 search the hacks thread for 2.0 reinstall. there is a step by step there. Quote Link to post Share on other sites
dragon24 Posted June 13, 2009 Author Report Share Posted June 13, 2009 thanks for the help... unit now just sits on the boot scrren & you can get to the menu & thats it. Hopefully this fresh install will work. Quote Link to post Share on other sites
ckelly33 Posted June 13, 2009 Report Share Posted June 13, 2009 I fixed a friend's that was doing the same thing. 1st, I tried to go into Testmode - that wouldn't complete either so next I put in the card from Pioneer w/2.0. It installed and I was able to boot up. I went back into testmode (which now worked) and put his hacks back in. Worked like a charm. Quote Link to post Share on other sites
dragon24 Posted June 15, 2009 Author Report Share Posted June 15, 2009 I also started with the testmode & nothing. so i put in the 2.0 update. That got me in the OS. I them reformated the flash where the software was & reinstalled it. I would say to everyone if they have a F90Bt or any of the AVIC radios to backup the software on an SD card just incase anythign happend to it. The fresh install to about 30-45 min Quote Link to post Share on other sites
ill.die.trying Posted June 15, 2009 Report Share Posted June 15, 2009 I also started with the testmode & nothing. so i put in the 2.0 update. That got me in the OS. I them reformated the flash where the software was & reinstalled it. I would say to everyone if they have a F90Bt or any of the AVIC radios to backup the software on an SD card just incase anythign happend to it. The fresh install to about 30-45 min i think this would be my last resort as from experience formatting makes things worst, but having a backup is always good Quote Link to post Share on other sites
ack154 Posted June 16, 2009 Report Share Posted June 16, 2009 I fixed a friend's that was doing the same thing. 1st, I tried to go into Testmode - that wouldn't complete either so next I put in the card from Pioneer w/2.0. It installed and I was able to boot up. I went back into testmode (which now worked) and put his hacks back in. Worked like a charm. This worked for me! Thank you! Would show splash screen for 15-20 seconds, then go black. Not just the screen, buttons too. But the unit was still "running." Test mode wouldn't work... would go partially through the initial copying and then black again. I was able to do the 2.0 update OK - though it seemed to be in a reboot loop afterwards. But that was OK cause I could at least then get back to Test Mode to copy my backup onto the system again. Backups are the BEST IDEA EVER! Then just had to adjust a few audio settings and I'm back in business. Quote Link to post Share on other sites
ewickj Posted June 16, 2009 Report Share Posted June 16, 2009 thanks this helped me out too i was having the same problem Quote Link to post Share on other sites
ckelly33 Posted June 16, 2009 Report Share Posted June 16, 2009 Glad it helped. I have two of these and it hasn't happened to me (yet!), but it did happen to my cousin's - which is the one we 'fixed'. I wonder what causes it?? Quote Link to post Share on other sites
