HAAK31 Posted June 19, 2009 Report Share Posted June 19, 2009 What i am more interested to find out is if you can use testmode to copy and paste to and from the flash now, have you tried to do that yet ? YES I did full update & later downgrade wince img, now 100% access to MY flash How is the downgrade done? Can't really find it out on that post. Quote Link to post Share on other sites
konick Posted June 19, 2009 Report Share Posted June 19, 2009 Go back to viewtopic.php?f=32&t=24956 Quote Link to post Share on other sites
ovalball Posted June 20, 2009 Report Share Posted June 20, 2009 Excellent work my friend.Can now install the Apps to my 900BT even though I had upgraded to 2.007>Thank you very much for the info. Quote Link to post Share on other sites
mr_cs Posted June 29, 2009 Report Share Posted June 29, 2009 Has anyone tried this ultimate launcher software? Thanks Colin Quote Link to post Share on other sites
hkgms3 Posted July 1, 2009 Report Share Posted July 1, 2009 First I will say is I know Testmode R2.3 is reported working. That is a good news. But at the same time, I am thinking out loud... When I was looking into the update from Pioneer, I was wondering if we can just modify the data.zip in the update before actually updating the system. Looks like the update should just simply coping all the files on the SD to the HU. If that is the case, and if Testmode will not work in the future updates, could we use the same method by modifying the data.zip in the update before updating the system. Better yet, if the HU let us re-done the same version of the update oven and oven again, then we can keep modifying the data.zip and installs it to the system using the same method. Quote Link to post Share on other sites
BorisM Posted July 1, 2009 Report Share Posted July 1, 2009 First I will say is I know Testmode R2.3 is reported working. That is a good news. But at the same time, I am thinking out loud... When I was looking into the update from Pioneer, I was wondering if we can just modify the data.zip in the update before actually updating the system. Looks like the update should just simply coping all the files on the SD to the HU. If that is the case, and if Testmode will not work in the future updates, could we use the same method by modifying the data.zip in the update before updating the system. Better yet, if the HU let us re-done the same version of the update oven and oven again, then we can keep modifying the data.zip and installs it to the system using the same method. This has been proposed many times and no, it will never worked, unless you also modify the checksum that updater uses to make sure that files being copied are correct. Quote Link to post Share on other sites
hkgms3 Posted July 1, 2009 Report Share Posted July 1, 2009 First I will say is I know Testmode R2.3 is reported working. That is a good news. But at the same time, I am thinking out loud... When I was looking into the update from Pioneer, I was wondering if we can just modify the data.zip in the update before actually updating the system. Looks like the update should just simply coping all the files on the SD to the HU. If that is the case, and if Testmode will not work in the future updates, could we use the same method by modifying the data.zip in the update before updating the system. Better yet, if the HU let us re-done the same version of the update oven and oven again, then we can keep modifying the data.zip and installs it to the system using the same method. This has been proposed many times and no, it will never worked, unless you also modify the checksum that updater uses to make sure that files being copied are correct. Too bad. And I was thinking I were so smart for about a second... Quote Link to post Share on other sites
BorisM Posted July 1, 2009 Report Share Posted July 1, 2009 Too bad. And I was thinking I were so smart for about a second... Pioneer would not want to support everyone who has a corrupt download, flashes it into AVIC and ends up bricking it. That's why they (and everyone else who uses updaters like that) include integrity checks to make sure that what is being installed is exactly what was offered for download. Quote Link to post Share on other sites
Bman69 Posted July 2, 2009 Report Share Posted July 2, 2009 um well it shouldnt be that hard to change the checks that pioneer added and just use the new hash or crc whatever check it does with a modified data.zip Quote Link to post Share on other sites
mygalles Posted July 2, 2009 Report Share Posted July 2, 2009 hello I have testing ultimate launcher, but I have an error message : error /st.... /APL/-h on boot and nothing.... sorry Quote Link to post Share on other sites
