TimboCummins Posted June 19, 2009 Report Share Posted June 19, 2009 Just purchased the CD-UB100 USB adapter. The unit will only detect the USB thumb drive if I disconnect and reconnect the ip out cable. This has to be accomplished each time the USB thumb drive is reconnected. Works 0% of the time if you just insert the thumb drive and works 100% of the time if you disconnect and reconnect the ip cable. I have reset the unit several times. I have replaced the unit and all wiring with another unit. I have directly connected the thumb drive to the CD-UB100, the results are the same. I have varied the CD-UB100’s position in the daisy chain and no change. Any ideas. Tried searching long enough. Thanks http://dodgetruckworld.tenmagazines.com/gallery/Timbocummins/396297.jpg http://dodgetruckworld.tenmagazines.com/gallery/Timbocummins/396302.jpg Quote Link to post Share on other sites
CaptainInsaneO Posted June 19, 2009 Report Share Posted June 19, 2009 Have you tried switching the source on the Z unit? That's a dumb question to ask, I know... but it's the only thing I can think of. Quote Link to post Share on other sites
Tillude Posted June 19, 2009 Report Share Posted June 19, 2009 maybe this could be the solution , i had the same problem connecting a hard drive to the F900 viewtopic.php?f=34&t=24960 Quote Link to post Share on other sites
TimboCummins Posted June 19, 2009 Author Report Share Posted June 19, 2009 The USB is currently recognized as ext1. How do I change that to another source? Thanks for the response Quote Link to post Share on other sites
CaptainInsaneO Posted June 19, 2009 Report Share Posted June 19, 2009 I'm sorry I was pretty vague... I meant actually going into the Z interface and chooing the flash drive through there (like pressing AUX1 or EXT1, whatever it is) I was thinking maybe that would make it work somehow. I honestly have never hooked anything up to USB on my Z so I dunno for sure. Quote Link to post Share on other sites
TimboCummins Posted June 19, 2009 Author Report Share Posted June 19, 2009 Thanks however I have tired every setting there is. Nothing seems to work except unplugging the ip connector or resetting each time a different or the same thumb drive is inserted. Quote Link to post Share on other sites
bridge4d Posted June 19, 2009 Report Share Posted June 19, 2009 What kind of thumbdrive? Which file system is it running? Are you using proprietary software to add files to it or just drag/drop? Quote Link to post Share on other sites
TimboCummins Posted June 19, 2009 Author Report Share Posted June 19, 2009 I have tried several thumb drives and get the same result; I have formatted all drives with fat32. I just drag and drop to add the files. Thank you for your response. Quote Link to post Share on other sites
bridge4d Posted June 20, 2009 Report Share Posted June 20, 2009 Which Avic? Z1, 2 or 3? Native or upgrade? Quote Link to post Share on other sites
TimboCummins Posted June 20, 2009 Author Report Share Posted June 20, 2009 avic z1 was recent rebuild under warrenty Quote Link to post Share on other sites
bridge4d Posted June 20, 2009 Report Share Posted June 20, 2009 Hmmmm No clue. Maybe you have a bad CD-UB100? You might want to try doing the available software upgrade to your unit...at least to the Z2 software and see if that fixes it. Also, return the CD-UB100 and get a new one. Quote Link to post Share on other sites
TimboCummins Posted June 20, 2009 Author Report Share Posted June 20, 2009 the unit has already been returned and the new one does the same thing. scared to death to try an update, I will live with the current situation. I just keep the entire usb unit in my glove box and reconnect the ip cable when switching drives. Thanks for all the input Quote Link to post Share on other sites
bridge4d Posted June 20, 2009 Report Share Posted June 20, 2009 Everything is better after an update Quote Link to post Share on other sites
TimboCummins Posted June 24, 2009 Author Report Share Posted June 24, 2009 If you say everything is better after an update then maybe I should do it. I am just so happy with the unit as is and willing to live with this usb problem. I have had problems with updates with other equipment in the past but if you say it should go well then I will give it thought. I guess you are talking about the z3 update, will this erase my stored music? Quote Link to post Share on other sites
