Mayoo Posted June 29, 2009 Report Share Posted June 29, 2009 I all. I recently took a week off and gave my car to the repair shop for some rust removing. When I got it back a week later, the arrow showing my position started to show me sideways on the gps. This is really a pain since avic has a hard time helping me with naviguation since he doesn't really know where I am going. Anyone had this problem ? Should I continue trying with Pioneer or tell the repair shop they broke my gps ? Avic-Z2 + ND-BT1 VSS is wired In a Mazda 3 2004 I tried multple soft resets but didn't helped. Thank you for your help ! Quote Link to post Share on other sites
bloodninja Posted June 29, 2009 Report Share Posted June 29, 2009 Does it always point North? There may be a setting to either have it always face north, or auto-rotate the map. Maybe it's set to always point North. Quote Link to post Share on other sites
Mayoo Posted June 29, 2009 Author Report Share Posted June 29, 2009 for the map yes but not for the arrow. I got it to worka few minutes ago. I had to reset the 3D sensor. kindda weird but hopefully everything is back to normal. Quote Link to post Share on other sites
TheGenius76 Posted July 8, 2009 Report Share Posted July 8, 2009 for the map yes but not for the arrow. I got it to worka few minutes ago. I had to reset the 3D sensor. kindda weird but hopefully everything is back to normal. Same thing happened to mine. Sounds like you may not have the VSS wire hooked up properly. A simple reset like you did, should fix the problem temporally. A permanent fix would be to have that wire connected properly Quote Link to post Share on other sites
zukgod1 Posted July 10, 2009 Report Share Posted July 10, 2009 3d calibration rest will fix you up my son Had the same problem, had to reset it twice before it finally went the correct direction. i also do not have the VSS wire hooked up. Quote Link to post Share on other sites
