diaftia Posted August 18, 2009 Report Share Posted August 18, 2009 I updated a while back to the 3.01 found on this forum. Previously I had purchased the official update from Pioneer. I thought that when it got here I would just install fresh and start over so I was official. Problem is when I place SD card 1 into the unit it just boots normally. When I put SD card 2 into the system to do the MSN update it just tries to play the sounds files it finds on the card. I did check and if memory serves me correctly my MSN was 2.2 and the version to update to was 2.6. So it does need updating. Has anyone else with the hacked 3.0 tried to install the official 3.0? Quote Link to post Share on other sites
infochia Posted August 19, 2009 Report Share Posted August 19, 2009 Did you try downgrading your firmware back to your pre-3.0 / 3.01 state? I don't know if that's the only answer, but I think it would solve your problem. Keep us updated please? good luck! infochia Quote Link to post Share on other sites
diaftia Posted August 19, 2009 Author Report Share Posted August 19, 2009 Here is the solution: viewtopic.php?f=32&t=26613 Quote Link to post Share on other sites
