Mitty Posted September 11, 2009 Report Share Posted September 11, 2009 Hey... i just bought the 910 and i was told that you can not play DVD's while the vehicle is moving. Is there any way around this? Thank you Quote Link to post Share on other sites
bloodninja Posted September 12, 2009 Report Share Posted September 12, 2009 Hey... i just bought the 910 and i was told that you can not play DVD's while the vehicle is moving. Is there any way around this? Thank you That's what the "Parking Brake Bypass" is for Quote Link to post Share on other sites
Mike S Posted September 12, 2009 Report Share Posted September 12, 2009 There's a hardware bypass and a software bypass you can do. Check the F series boards for details. Quote Link to post Share on other sites
Mitty Posted September 12, 2009 Author Report Share Posted September 12, 2009 i had a shop hook it up and they did put a switch that im suppose ot flip. but when i do it turns on/off the bluebooth option and map.. do you think they hooked it up incorrectly? I have been told that the video is connected with the GPS system and when the vehicle starts moving the gps senses the motion and shuts of fthe video. is this true? I know they have agreen cable and ground running the switch.. anyone knows the color of the cable? Quote Link to post Share on other sites
Mitty Posted September 12, 2009 Author Report Share Posted September 12, 2009 There's a hardware bypass and a software bypass you can do. Check the F series boards for details. i have firmware 3.0 do you know where i can get the software with instructions?? thanks Quote Link to post Share on other sites
ill.die.trying Posted September 12, 2009 Report Share Posted September 12, 2009 There's a hardware bypass and a software bypass you can do. Check the F series boards for details. i have firmware 3.0 do you know where i can get the software with instructions?? thanks f-series forum on the hacks thread section Quote Link to post Share on other sites
ill.die.trying Posted September 12, 2009 Report Share Posted September 12, 2009 i had a shop hook it up and they did put a switch that im suppose ot flip. but when i do it turns on/off the bluebooth option and map.. do you think they hooked it up incorrectly? I have been told that the video is connected with the GPS system and when the vehicle starts moving the gps senses the motion and shuts of fthe video. is this true? I know they have agreen cable and ground running the switch.. anyone knows the color of the cable? they have it installed correctly it is true Quote Link to post Share on other sites
xtreme17618 Posted September 12, 2009 Report Share Posted September 12, 2009 This bypass works for the 910 too. It works great, just watch the video. I can call dial, watch videos and everything as if I was parked. Let me know if you need help. Good luck Quote Link to post Share on other sites
Mike S Posted September 12, 2009 Report Share Posted September 12, 2009 Try this thread. I did the hardware bypass, so I'm not familiar with the alternative method. Software mod "bypass" confirmed - Put away your wi Quote Link to post Share on other sites
