Jeffs64 Posted November 15, 2009 Report Share Posted November 15, 2009 Does the metal plate really help ? Or is it just so the magnet on the antenna will hold the antenna in place Quote Link to post Share on other sites
terron Posted November 15, 2009 Report Share Posted November 15, 2009 I'm not entirely sure what the purpose of the metal plate is aside from securing the movement of the receiver. My antenna sits atop a speaker in my dash corner and works fine, although my altitude is always off about 20-30 ft but location is spot-on. Quote Link to post Share on other sites
Jeffs64 Posted November 16, 2009 Author Report Share Posted November 16, 2009 To terron Mine is localed my top of the dashboard on the drivers side with dubble sided tape, seems just to work just fine. Is there an altiminer on the display somewhere ? I have not noticed it. 3.0 update F90BT Thanks Jeff R. Quote Link to post Share on other sites
terron Posted November 16, 2009 Report Share Posted November 16, 2009 To terron Mine is localed my top of the dashboard on the drivers side with dubble sided tape, seems just to work just fine. Is there an altiminer on the display somewhere ? I have not noticed it. 3.0 update F90BT Thanks Jeff R. I run the IDT skin/mod so it has an altimeter on the screen, but you'll also see one when looking at the sat signal in the navi/settings menu. Quote Link to post Share on other sites
1loudls Posted November 18, 2009 Report Share Posted November 18, 2009 the metal piece is supposed to help with reception, nav and sat radio antenna's are designed to be mounted on a piece of metal of a certain minim size kinda like how the dish part of a DirecTV dish focuses the signal into the LNB and the metal sheet is for when you don't have it on a metal body panel. how important is it, not too important. the only time i use it is when i mount the antenna under the dash. Quote Link to post Share on other sites
