bogiedogie Posted December 3, 2009 Report Share Posted December 3, 2009 The instructions tell me to hook this up to the light block. DOes anyone know exactly what this accomplishes? i see my prior install by best buy of my f700 did not hook this up. I was alway unhappy that i had to manually dim the screen at night. i know there is a night/day setting, but i have never seen a big difference (maybe because this lead was never hooked up?) if i hook this up to the headlight juice, will it dim the screen automatifcally? I called pioneer 2x and asked and could not get a good answer. i am asking here becasue i am sure you guys know more than they do. I fi hook it to the dimmer part of the light block will that dim the screen? or does it just automaticaly swithc it to night mode where i never saw a big difference, and did i not see a difference because it was never hooked up and made this feature disabled? any suggestions woul dbe appreciated. Quote Link to post Share on other sites
Newman Posted December 3, 2009 Report Share Posted December 3, 2009 the unit should automatically dim when the headlights turn on and go back to full brightness when the headlights are off. the dimmer knob on your dash will not do anything. "daytime" and "nighttime" mode for the nav have nothing to do with this. that changes the background color of the map screen to black at night and yellow in the day. this is done via the GPS clock i believe. if you want your screen to be brighter or dimmer at night, make sure the headlights are ON and then change the brightness. if you want your screen to be brighter or dimmer during the day, make sure the headlight are OFF and change the brightness. whatever mode you want to change the brightness for, make sure that mode is active when changing the settings. Quote Link to post Share on other sites
bogiedogie Posted December 3, 2009 Author Report Share Posted December 3, 2009 THanks so much for the info. i suspected teh day night mode would not do this based on what the user's manual said. i kind of annoyed best buy did not run this lead even though i paid full price for install. i am going to install the new unit myself. thanks again. Quote Link to post Share on other sites
sontt007 Posted June 12, 2010 Report Share Posted June 12, 2010 Hi, so I have to connect this orange lead to the (+) wire of the parking light or headlight ? IS THAT CORRECT OR NOT ? THANKS. Quote Link to post Share on other sites
