Pogigreg Posted December 27, 2009 Author Report Share Posted December 27, 2009 I'll try some more, tomorrow. My truck has had every Avic from the D1 to the D3, then the Z1, now the Z110BT. First time I have problems from the moment I Install. I can't help but to wonder if I have a perfect storm of malfunctions? Quote Link to post Share on other sites
CamelTowing Posted December 27, 2009 Report Share Posted December 27, 2009 Is the antenna in the same spot mounted on something metal that your previous decks were? If it is, I would tend think you got the one in a thousand or more that has a bad gyro. Zero learning on the Left & Right is kind of suspicious. Quote Link to post Share on other sites
Pogigreg Posted December 27, 2009 Author Report Share Posted December 27, 2009 I am more inclined to believe that I have a bad gyro. All of the symptoms lead to it. I have a fully working D3 on my work bench. I can turn the unit itself to the left or the right, and I can see the turns registered on on the 3D calibration screen. My previous installs, I had my antenna mounted on the roof of my Suburban. Since I started out with a D1, then a D3, and then to a Z1, I never had to change the antenna. From the original installation, I ran the pink wire to the VSS. I couldn't help but to wonder do I need to retap it? Quote Link to post Share on other sites
VBLUE42 Posted December 27, 2009 Report Share Posted December 27, 2009 Your problem is not the VSS regardless if it is connected or not. Quote Link to post Share on other sites
Pogigreg Posted December 29, 2009 Author Report Share Posted December 29, 2009 I swapped out the Z110 with a new one. This one is working fine. The other one had all kind of gremlins in it. Thanks VBLUE42 for your help. Quote Link to post Share on other sites
Join the conversation
