Zrz11386 Posted January 3, 2010 Report Share Posted January 3, 2010 So I had my Z110BT installed in my '06 Mustang after my D3 was stolen. Everything looks and works great except for 1 thing: Each time I put in an address in the Navi, I get the result "Address Not Found". It doesnt matter which address I put in, including my home, it can't find it. It will narrow the results down to a city, and then kick me out saying it cant find it. Every once in awhile it will say it cant find the street, but not always. Can anyone help me figure out why I cant find any addresses? By the way, I apologize if this question has been answered in a previous thread, I tried a search but couldnt come up with anything. As always, thanks in advance to those with more knowledge than I. -Zach Quote Link to post Share on other sites
mazu Posted January 3, 2010 Report Share Posted January 3, 2010 Yes, I have this problem. Help please. Quote Link to post Share on other sites
VBLUE42 Posted January 3, 2010 Report Share Posted January 3, 2010 Make sure you are selecting the city before you attempt to type in the address. Also make sure you have the correct state selected. Quote Link to post Share on other sites
Zrz11386 Posted January 3, 2010 Author Report Share Posted January 3, 2010 Usually when Im entering an address, I enter a house number first, then a street name, and then it usually gives me a list of cities or towns that match the street and house number. This was how I used to do it on my D3, so based off of what you had said, im doing it wrong, is that right? Could you tell me how I should be entering it? Thanks for the quick reply. I appreciate it. Quote Link to post Share on other sites
VBLUE42 Posted January 3, 2010 Report Share Posted January 3, 2010 You can not enter address info until you enter the city. Its right there on the screen. Quote Link to post Share on other sites
CamelTowing Posted January 3, 2010 Report Share Posted January 3, 2010 Did you double check the state you are searching in? The D3 you only had to choose a 'zone' with your state in it, not the actual state Quote Link to post Share on other sites
Zrz11386 Posted January 3, 2010 Author Report Share Posted January 3, 2010 Well from the way Im doing it, I dont actually enter a state. I just type in house number, then street name and it gives me results. For instance: House Number: 1707 Street Name: Baker Street Then it will bring up a list of Baker Streets such as: Baltimore, MD Tallahassee, FL Baton Rouge, LA York, PA Wilmington, DE Reston, VA When I touch Baltimore, MD, which is where I live, it will prompt me; "ADDRESS NOT FOUND" and then kick me back to the Navi Menu screen. From what VBLUE was saying, it seems like I need to first enter the state then the address itself. Im not exactly sure how to go about doing that, BUT I havent had the chance to try yet, so dont call me stupid just quite yet. However if anyone knows what im doing wrong off the top of their head and could tell me how to fix it. Id appreciate it. Thanks again to the posters above for their help. Quote Link to post Share on other sites
mazu Posted January 3, 2010 Report Share Posted January 3, 2010 I have the same problem I have everything in order, so Country: Chile City: Antofagasta address: "Travesia del Sur" "address not found" ... but I can see that address on the map, but I can not find it in "address" Is it possible that the maps are defective? map: http://www.igomyway.com/iphone/es/igomyway_Chile.html Quote Link to post Share on other sites
jwq Posted January 3, 2010 Report Share Posted January 3, 2010 I have the same problem I have everything in order, so Country: Chile City: Antofagasta address: "Travesia del Sur" "address not found" ... but I can see that address on the map, but I can not find it in "address" Is it possible that the maps are defective? map: http://www.igomyway.com/iphone/es/igomyway_Chile.html Try entering only a partial street address, f.i. trav and using "list" to see what comes up.... Maybe it's spelled slightly differently on the z110 Quote Link to post Share on other sites
CamelTowing Posted January 3, 2010 Report Share Posted January 3, 2010 First, choose the state. Also on street name, try typing in just 'Baker' Some streets are in their database as St instead of Street. Well from the way Im doing it, I dont actually enter a state. I just type in house number, then street name and it gives me results. For instance: House Number: 1707 Street Name: Baker Street Then it will bring up a list of Baker Streets such as: Baltimore, MD Tallahassee, FL Baton Rouge, LA York, PA Wilmington, DE Reston, VA When I touch Baltimore, MD, which is where I live, it will prompt me; "ADDRESS NOT FOUND" and then kick me back to the Navi Menu screen. From what VBLUE was saying, it seems like I need to first enter the state then the address itself. Im not exactly sure how to go about doing that, BUT I havent had the chance to try yet, so dont call me stupid just quite yet. However if anyone knows what im doing wrong off the top of their head and could tell me how to fix it. Id appreciate it. Thanks again to the posters above for their help. Quote Link to post Share on other sites
VBLUE42 Posted January 3, 2010 Report Share Posted January 3, 2010 First of all, using the VR would be a lot easier because it verbally walks you through the prompts. Also a look over pages 55-57 in the manual should also help. Quote Link to post Share on other sites
Zrz11386 Posted January 4, 2010 Author Report Share Posted January 4, 2010 Whenever I've tried the VR to put in an address, I always get the prompt "VR engine starting up". So I just tried to put it in manually and then came across this issue, but thanks ill try that tomorrow. Quote Link to post Share on other sites
VBLUE42 Posted January 4, 2010 Report Share Posted January 4, 2010 On the map screen, once you hit the OK button, wait 30 seconds before trying to use the VR or it will fail until you restart the unit. Quote Link to post Share on other sites
dawgbone Posted January 5, 2010 Report Share Posted January 5, 2010 On the map screen, once you hit the OK button, wait 30 seconds before trying to use the VR or it will fail until you restart the unit. It appears to be only one right start-up routine that works correctly with this unit.... I've emailed Pioneer about it, as well as posted on there YouTube Channel about it.... I figure bugs being reported out in the public, will get their attention.... after all, it is their flagship Nav unit.... Quote Link to post Share on other sites
VBLUE42 Posted January 5, 2010 Report Share Posted January 5, 2010 I also posted to your comment in detail and that is an excellant idea. It is sad but this may be the only way to get accross to them to get things addressed. I wont hold my breath though. Quote Link to post Share on other sites
