gar_lei Posted January 13, 2010 Report Share Posted January 13, 2010 Hello I'm getting rid of my F700 and getting the Z110BT, would I need to do anything to my PAC SWIPS or it'll be plug n play? And also I'm using another mic then the one I got with my F700. Its a Parrot mic that I bought afterward and ppl said that it sounds much better then the stock one from F700. Would I be able to keep using that mic? Thanks! Quote Link to post Share on other sites
VBLUE42 Posted January 14, 2010 Report Share Posted January 14, 2010 Yes and yes. However, Unless you have the SWI-PS version 1.6.8 you will not be able to program the controls to take advantage of the voice control with your steering controls. Obviously, if you do upgrade to the 1.6.8 version it will have to be programed. Quote Link to post Share on other sites
gar_lei Posted January 14, 2010 Author Report Share Posted January 14, 2010 Is there a easy way to check which version of PAC SWIPS I have? Cause I only ordered it on eBay 1 year ago and gave it to the installer to take care of it... Thansk a lot! Quote Link to post Share on other sites
VBLUE42 Posted January 14, 2010 Report Share Posted January 14, 2010 If your PS is a year old you don't have 1.6.8 as it was just released 30 or so days ago. Quote Link to post Share on other sites
gar_lei Posted January 14, 2010 Author Report Share Posted January 14, 2010 If your PS is a year old you don't have 1.6.8 as it was just released 30 or so days ago. Oh ic... With the new one I would be able to control via BT and VR that the old one doesn't right? Quote Link to post Share on other sites
VBLUE42 Posted January 14, 2010 Report Share Posted January 14, 2010 Yes. Quote Link to post Share on other sites
ZoOmZoOmPoW Posted January 22, 2010 Report Share Posted January 22, 2010 A shop installed pac-swips on the z110BT but my bluetooth and VR did not work on my Mazda 3 2010 steering wheel controls. It cannot be program. It is version 1.6.8 and they tried two modules with 1.6.8, no luck. Everytime a tech tried to program the BT function, it just shuts off. Shop told me they will order more 1.6.8 and try again next week. Do you guys think the PAC is defective or is there a different way to program depends on car models/make ? Quote Link to post Share on other sites
VBLUE42 Posted January 22, 2010 Report Share Posted January 22, 2010 Either they are programing them wrong or they are using an older version then 1.6.8. Quote Link to post Share on other sites
gar_lei Posted January 24, 2010 Author Report Share Posted January 24, 2010 Yes and yes. However, Unless you have the SWI-PS version 1.6.8 you will not be able to program the controls to take advantage of the voice control with your steering controls. Obviously, if you do upgrade to the 1.6.8 version it will have to be programed. I just installed my Z110BT today and I plugged the PAC back in with out changing the programing of it and it simply WORKS! So basically it was plug and play for my upgrade from F700. Quote Link to post Share on other sites
VBLUE42 Posted January 25, 2010 Report Share Posted January 25, 2010 You will not get VR if you do not have version 1.6.8. Quote Link to post Share on other sites
Ferendon Posted January 28, 2010 Report Share Posted January 28, 2010 A shop installed pac-swips on the z110BT but my bluetooth and VR did not work on my Mazda 3 2010 steering wheel controls. It cannot be program. It is version 1.6.8 and they tried two modules with 1.6.8, no luck. Everytime a tech tried to program the BT function, it just shuts off. Shop told me they will order more 1.6.8 and try again next week. Do you guys think the PAC is defective or is there a different way to program depends on car models/make ? What buttons on the steering wheel were they trying to use for the VR? Not all of the buttons share the same CANbus wires, so it made need a second SWI-PS. If it's buttons for factory bluetooth, then they probably communicate with the bluetooth module, and not the radio. Quote Link to post Share on other sites
