SFYellow Posted January 15, 2010 Report Share Posted January 15, 2010 Hey guys anybody installed Samantha TTS on the 3.1? Is there a difference in TTS files and/or install between 3.1 and lets say 2.0? Where can I find Samantha TTS files? Quote Link to post Share on other sites
jmuenni Posted January 16, 2010 Report Share Posted January 16, 2010 Here you go. Works fine on 3.01 Voice_TTS-nua-eng-us-f1.zip Quote Link to post Share on other sites
hanibal Posted January 16, 2010 Report Share Posted January 16, 2010 can we add other voices? If so where can we find some? Quote Link to post Share on other sites
jezikk Posted January 17, 2010 Report Share Posted January 17, 2010 hello, I will hijack the treat a little bit and and if somebody have a polish TTS voice ? I downloaded from the internet a couple but none of them worked with my avic F910. thx in advance Quote Link to post Share on other sites
SFYellow Posted January 19, 2010 Author Report Share Posted January 19, 2010 Here you go. Works fine on 3.01 Thank you! Do I need to unzip these files before putting them on SD card? Quote Link to post Share on other sites
jezikk Posted January 19, 2010 Report Share Posted January 19, 2010 No, You just boot your avic into test mode and copy it to My Flash Disk/APL2/Igo/Content/Voice and later in the setting you choose Samanta TTS. Quote Link to post Share on other sites
SFYellow Posted January 19, 2010 Author Report Share Posted January 19, 2010 No, You just boot your avic into test mode and copy it to My Flash Disk/APL2/Igo/Content/Voice and later in the setting you choose Samanta TTS. Ooo I see. I had completely wrong instructions on how to install it. Thank you!!! Quote Link to post Share on other sites
hanibal Posted January 19, 2010 Report Share Posted January 19, 2010 where can we download cutom ones? Quote Link to post Share on other sites
SooTyLaD Posted January 26, 2010 Report Share Posted January 26, 2010 Can I ask, for the voice thing to work do I just need: • Voice_Eng-uk-f1.zip & • Voice_TTS-nua-eng-uk-f1.zip ? Or do I also maybe need the Voice_Tur-f21.zip file? What is the difference between these files? I ask because I spannered up my F710BT but found an X910BT backup and have used that, merged in the 3.02 update, merged in the Diaftia Hybrid & the latest maps and it all works except the voice, although I haven't deleted the save files yet which I have a feeling will help... Either way would like to know what the above files are and if they are all required Quote Link to post Share on other sites
SFYellow Posted January 26, 2010 Author Report Share Posted January 26, 2010 Can I ask, for the voice thing to work do I just need: • Voice_Eng-uk-f1.zip & • Voice_TTS-nua-eng-uk-f1.zip ? Or do I also maybe need the Voice_Tur-f21.zip file? What is the difference between these files? I ask because I spannered up my F710BT but found an X910BT backup and have used that, merged in the 3.02 update, merged in the Diaftia Hybrid & the latest maps and it all works except the voice, although I haven't deleted the save files yet which I have a feeling will help... Either way would like to know what the above files are and if they are all required Just use the file that is provided above unzip it and put it on your Avic system via test mode. It will take care of the TTS. Quote Link to post Share on other sites
SooTyLaD Posted January 26, 2010 Report Share Posted January 26, 2010 yeah but that zip is a US one not UK, surely that wouldn't do the job? Quote Link to post Share on other sites
SooTyLaD Posted January 27, 2010 Report Share Posted January 27, 2010 later in the setting you choose Samanta TTS. Maybe I'm being really blind, but where do you choose this setting? I have the two lots of UK voice zip files on the unit but like I said just get a muted second of music but no voice still... maybe if I can just point it to the right one? Had a good look through the nav settings but just can't see anything EDIT: you can pretty much ignore this I've just read somewhere that its in regional settings... thanks anyway Quote Link to post Share on other sites
