Guest Posted May 16, 2006 Report Share Posted May 16, 2006 I want to install this myself, and i need some good step by step instructions for this install...also how to bypass the dvd player as i would like this option...any help would be grately appreciated...Thanks, Clay Quote Link to post Share on other sites
blackEJ20 Posted May 25, 2006 Report Share Posted May 25, 2006 Clay, you're going to have to be a lot more specific with the details of your install to get the right info. lets start with the year & model accord. you'll need a wiring schematic of your particular model...an adaptor harness is probably available but with many of the new model accords that have integrated hvac/radio controls it gets really iffy w/ aftermarket HU install's. I have plenty of access to wiring diagrams if you need it - i am a parts guy at a Honda dealership. every install is a little different, so there is no one "DIY" guide to follow. Chances are though that this has been done...there is probably some info regarding this setup on honda-tech.com or a another similar honda specific forum.. google is your friend! as far as the n2 bypass goes, it's on here ...take a look in the the n1/n2/n3 hacks/mods forums. its there (with pictures too!). good luck Quote Link to post Share on other sites
BigCountry06 Posted May 27, 2006 Report Share Posted May 27, 2006 its an 2000 coupe (maybe EX) not 100% sure...(as this is my bro's car im trying to help him install the N2)...i know it has the factory 6disc cd with leather sunroof V6 etc...ill be installing the Avic-Z1 in my truck, just not sure how similar the wiring will be...i have a pretty good idea how to run the Z1, w/pics and all, just not many posts on the n2 from what i can see....so any kinda wiring diagram on this unit or help would be greatly appreciated....Thanks Quote Link to post Share on other sites
robtse Posted December 3, 2006 Report Share Posted December 3, 2006 just match the wiring harness colors together. make sure u connect the green wire thats sappose to go to the brake to the ground. try not to soder the 2 contacts under the sticker use the foil method or the circuit pen. soder it has a high risk of fucking something up. the contacts are tiny and the heat will either take off to much or put too much on it. Quote Link to post Share on other sites
