mcgilles Posted February 15, 2010 Report Share Posted February 15, 2010 what is the effect of not connecting the speedometer signal? the manual says to always connect it, but it also says that it just makes the computations more accurate, suggesting that the GPS based calculation will still work, but might not be as good. I don't want to hook up this signal if I can avoid it. I know it has nothign to do with the bypass but I don't like the idea of tapping into the speedometer signal. my garmin GPS calculates the vehicle speed to within 1mph, would the pioneer really be that far off? Quote Link to post Share on other sites
VBLUE42 Posted February 15, 2010 Report Share Posted February 15, 2010 If driving in a tunnel, deeply forested area, or city with many sky scrapers, yes, it could make a difference. Other then that, don't worry about it. Quote Link to post Share on other sites
stoveken Posted February 15, 2010 Report Share Posted February 15, 2010 makes a big overall difference i always hook it up. what year make and model is your car ? ill tell you where to get the speed wire. jim Quote Link to post Share on other sites
mcgilles Posted February 15, 2010 Author Report Share Posted February 15, 2010 makes a big overall difference i always hook it up. what year make and model is your car ? ill tell you where to get the speed wire. jim Its a C5 Corvette. I think I know where to get my hands on the signal right behind the instrument cluster. its a pain to get to but not the end of the world. I am just nervous about the concept of tapping into a wire like that. how can I be sure that its perfectly safe to do so? how can I be sure that the addition of some other circuit elements won't throw my speedo reading off? I guess most people do this and I suppose no one has ever had a problem before (unless you do something crazy like damage the stock wire, break it off or poorly tap it or something) Is this really a safe thing to do? no risk to the stock electronics? thanks for your help! Quote Link to post Share on other sites
dallas5cowns Posted February 15, 2010 Report Share Posted February 15, 2010 I just installed this unit in my '02 Z06 at the first of the year, made the connection behind the main instrument panel and I've absolutely no issues. Quote Link to post Share on other sites
stoveken Posted February 16, 2010 Report Share Posted February 16, 2010 make a good connection. dont short the wire no problems. do it everyday. jim if your factory radio had speed senssitive volume the vss wire will be at factory radio harness. get me the year etc jim Quote Link to post Share on other sites
mcgilles Posted February 16, 2010 Author Report Share Posted February 16, 2010 I just installed this unit in my '02 Z06 at the first of the year, made the connection behind the main instrument panel and I've absolutely no issues. thanks! I guess I'll make the attempt. might as well since I have to replace one of the LEDs in my DIC buttons anyway, the cluster needs to come out while everything else is apart. Quote Link to post Share on other sites
mcgilles Posted February 16, 2010 Author Report Share Posted February 16, 2010 make a good connection. dont short the wire no problems. do it everyday. jim if your factory radio had speed senssitive volume the vss wire will be at factory radio harness. get me the year etc jim actually it isn't the case with this car for some reason. it does have SCR on the factory radio, but there isn't any VSS signal on the connector (haven't actually inspected the service manual on this, trusted people on the forum) apparently this car's stock radio got the VSS information through the serial data cable which forms the network that all the car's computers talk to each other on. odd thing is on the newer C6's there is a VSS wire in the stock wiring harness. but in the C5 best bet is to tap into it behind the cluster. so I guess that's what I'll attempt. Quote Link to post Share on other sites
jmleaux Posted July 14, 2010 Report Share Posted July 14, 2010 I have a 2000 BMW M5 with a new Z120BT...GPS status says 'Speed Pulse = 0', which I assume means installer did not connect the pink wire. Should I care? Are there features that aren't going to work without this in place? Quote Link to post Share on other sites
WMack Posted July 14, 2010 Report Share Posted July 14, 2010 Does connecting this wire override the "in motion" hack on the 110bt? Quote Link to post Share on other sites
VBLUE42 Posted July 14, 2010 Report Share Posted July 14, 2010 No. Quote Link to post Share on other sites
WMack Posted July 14, 2010 Report Share Posted July 14, 2010 No. So no downside for installing it...other than the task of actually doing it. My dash is a pain to get into. Quote Link to post Share on other sites
dawgbone Posted July 15, 2010 Report Share Posted July 15, 2010 My dash is a pain to get into. So is everyone's..... If you have a decent grade vehicle... You can actually do it without breaking the tabs.... Quote Link to post Share on other sites
SMILE1059 Posted July 15, 2010 Report Share Posted July 15, 2010 Looking to install a Pioneer AVIC Z110BT which requires a connection to a speed detection/VSS wire. Any suggestions for the best location. I have 2009 ford expedition vss wire location Quote Link to post Share on other sites
garys35 Posted July 23, 2010 Report Share Posted July 23, 2010 Hi Everyone, I just found this site and it is answering alot of my questions. I will be Installing my new AVICZ 120 this weekend but I can't find information locating the speed wire connection and the reverse connection for a rear camera install. I have a Hyundai Sante Fe 2010 SUV standard stereo with no factory amp or sub . If anyone can help me on this I would appreciate it. Cheers Quote Link to post Share on other sites
