pbohart Posted March 29, 2010 Report Share Posted March 29, 2010 Hi guys. I had the installer install the optional XM radio tuner. I went to XM's website and registered the radio using the XMID, but I am only able to tune 3 channels: 000, 001, and 247. Is there something I need to do to gain access to all of the channels within my subscription? Thanks! Quote Link to post Share on other sites
Newman Posted March 29, 2010 Report Share Posted March 29, 2010 Those three channels are the 3 free preview channels you get when the unit is not activated. First, verify to make sure you have the correct radio ID number. If the number is corrtect, take your vehicle outside where it has a clear view of the sky and let it sit, with the radio powered on, for about 15 mins. if that does not work you need to have Xm re-send the activation signal. When you first activate your XM they request that you have your car outside and powered on for 15-20 mins until the unit is activated. if you did not do this the first time make sure you do it the 2nd time. i dont know if you can re-send the signal yourself online or not. you may have to call XM to have them do this. Quote Link to post Share on other sites
PaisanNYC Posted March 29, 2010 Report Share Posted March 29, 2010 Yes you can refresh online. I have refreshed online via my cell phone many times, this way i dont have to run inside to refresh on the PC, then run back outside to the car to start it up and put it on channel 1. Just go to http://refresh.xmradio.com and type in your radio ID on that screen. Quote Link to post Share on other sites
