HoustonInSeattle Posted April 13, 2010 Report Share Posted April 13, 2010 I just reistalled 3.0 and then upgraded it to 3.02. I then went back in and changed my data.zip to the software bypass version by opening, changing the limit to 128, etc... and re-zipped the file and pasted it back into my unit. It doesn't like my new file. I tried several different zipping programs to see if it has to do with how it is getting re-compressed (each time the new zipped file is smaller than the origianal Pioneer version). Does anyone have a bypass data.zip that works with 3.02? Thanks, I'm just sick of the parking break warning! Quote Link to post Share on other sites
BorisM Posted April 13, 2010 Report Share Posted April 13, 2010 I just reistalled 3.0 and then upgraded it to 3.02. I then went back in and changed my data.zip to the software bypass version by opening, changing the limit to 128, etc... and re-zipped the file and pasted it back into my unit. It doesn't like my new file. I tried several different zipping programs to see if it has to do with how it is getting re-compressed (each time the new zipped file is smaller than the origianal Pioneer version). Does anyone have a bypass data.zip that works with 3.02? Thanks, I'm just sick of the parking break warning! Just put an uncompressed pioneer.ini file into project_config subfolder of iGO's main folder and don't worry about zipping it. Quote Link to post Share on other sites
HoustonInSeattle Posted April 19, 2010 Author Report Share Posted April 19, 2010 I'm not compressing the pioneer.ini file itself. i have to extract the folders from data.zip, mod pioneer.ini, save it, the recompress the data folder so that it is once again data.zip. I think I am having the problem during that recompression. Quote Link to post Share on other sites
HoustonInSeattle Posted May 6, 2010 Author Report Share Posted May 6, 2010 Is there no one with a working bypassed DATA.zip? I really can't seem to make any moded one I make work. This sucks! Quote Link to post Share on other sites
BorisM Posted May 6, 2010 Report Share Posted May 6, 2010 Is there no one with a working bypassed DATA.zip? I really can't seem to make any moded one I make work. This sucks! You were told the most foolproof way of modding the speed control. Quote Link to post Share on other sites
HoustonInSeattle Posted May 26, 2010 Author Report Share Posted May 26, 2010 What you are telling me doesn't make sense. To even view the project_config subfolder the DATA.zip file must be unzipped. I do this, otherwise I cannot see the pioneer.ini file to even change it. I am not zipping pioneer.ini itself; I am not zipping the project_config subfolder--but, I must re-zip the DATA folder back into DATA.zip or else it can't be used by the navigation software. One can't just drop an augmented file into a zipped folder--that's not how data compression works. DATA.zip, however my system is re-zipping it, will not work in any other form other than its OEM state. I could change it all I wanted before 3.0201 and it would work just peachy. I just have hit a wall with 3.0201 and for some reason the tried and true methods that worked before are not working for me now. Quote Link to post Share on other sites
another gsxr 1k Posted May 26, 2010 Report Share Posted May 26, 2010 I'm not sure if it is the same or not but the system used to not like files zipped by winzip or the built-in windows compression. Use 7-zip and it should work. Quote Link to post Share on other sites
BorisM Posted June 1, 2010 Report Share Posted June 1, 2010 What you are telling me doesn't make sense. To even view the project_config subfolder the DATA.zip file must be unzipped. I do this, otherwise I cannot see the pioneer.ini file to even change it. I am not zipping pioneer.ini itself; I am not zipping the project_config subfolder--but, I must re-zip the DATA folder back into DATA.zip or else it can't be used by the navigation software. One can't just drop an augmented file into a zipped folder--that's not how data compression works. DATA.zip, however my system is re-zipping it, will not work in any other form other than its OEM state. I could change it all I wanted before 3.0201 and it would work just peachy. I just have hit a wall with 3.0201 and for some reason the tried and true methods that worked before are not working for me now. Since you obviously do not know how to work WInZIP properly, you were told how to give the system a modified file without zipping it up at all. Instead of telling us how data compression works, you could have just tried it... Quote Link to post Share on other sites
josieless Posted June 1, 2010 Report Share Posted June 1, 2010 Since you obviously do not know how to work WInZIP properly, you were told how to give the system a modified file without zipping it up at all. Instead of telling us how data compression works, you could have just tried it... This, if you use your zip program correctly you can edit the file without unzipping it in the first place in notepad. Quote Link to post Share on other sites
