mxpro Posted June 2, 2010 Report Share Posted June 2, 2010 The screen is stuck in full tilt position. When I push the tilt button the collapses to full down position, push the button again it goes to full tilted , sometimes it will go to closed position and 2-3 seconds it returns to full tilt position. I can sometimes it will allow me to force it to closed,but when the key is off and then restarted it goes to full tilt. Also when I push the tilt button I can here a slight click on the right side . ANY SUGGESTIONS? Quote Link to post Share on other sites
CaptainInsaneO Posted June 2, 2010 Report Share Posted June 2, 2010 Hold tilt down. Quote Link to post Share on other sites
mxpro Posted June 2, 2010 Author Report Share Posted June 2, 2010 Thanks for the response but holding the button down either doesn't work . It automatically returns to full tilted position even after going from the collapsed position or proding it to the fully closed position Quote Link to post Share on other sites
CaptainInsaneO Posted June 2, 2010 Report Share Posted June 2, 2010 That's strange, it should be giving you the option to adjust the tilt angle. Quote Link to post Share on other sites
mxpro Posted June 2, 2010 Author Report Share Posted June 2, 2010 The screen does come up with the two icons to adjust the tilt. but the friggin fartin thing still returns to the full tilt position. I also tried resetting the unit also with no luck Quote Link to post Share on other sites
antnee Posted June 7, 2010 Report Share Posted June 7, 2010 thats crazy this happened to me today too?! wtf. Quote Link to post Share on other sites
Bletz Posted June 8, 2010 Report Share Posted June 8, 2010 mine just did it yesterday as well, I think something is broken with the tilt. you can manually push it back into place then hold down the tilt ( for the adjustment screen ) then remove all tild with the ( -- ) key. having it now flat with no tilt at all. it doesnt fix the tilt but it does make the unit not lay down flat when you start the car. Does anyone have any ideas on how to fix the unit or what may have broken???? thanks Quote Link to post Share on other sites
