Need help moving these bmp's
here ya go:
746_32K_MN-663_32b.bmp -- address
746_32K_MN-664_32b .bmp --poi
746_32K_MN-665_32b. bmp --favorites
746_32K_MN-666_32b. bmp -- history
746_32K_MN-667_32b. bmp --usb
746_32K_MN-671_32b. bmp --home
746_32K_MN-668_32b. bmp --delete route
here ya go:
Thanks I knew you would know the names. By the way I figured out how to add the speedometer and to make the gps onmap not show up in Nav. Thanks for your help.
here ya go:
I am trying to either move the top blue bar up a little or the 3 icons (address, poi and favorites) down a tiny bit since if you notice in the top picture that the icons interfere with the blue bar. Does anyone know where in the data file I would be able to adjust the y value of these bmp's. Thank you
You cannot get into the coding of the Main/AV section, so you will not find the x/y value for bmp's. Use these files and they will solve your problem. Just extract them and put them in your 800_480 folder and say yes to overwrite.
icon replacements.rar
Dude that worked awesome. what did you do? I tried trimming the bmp's but nothing fixed the problem. thanks you are a great help to this forum. I am pretty psyched, I have finally gotten all of the mods to work with my data file without having to start from scratch. I even added the speedo and got the GPS issue fixed. Now all there is left to do is minor adjustments and visual fixes. The last thing I want to add is the fuel calculator and make new buttons for the image.res file, so this will be my new project. Again thanks for all your help.
Simple, I just removed the background, leaving the icons visible. It was the black background that was getting in the way of the top bar. Simple solution :)
