Steve192 Posted June 13, 2010 Report Share Posted June 13, 2010 Hello everybody, I have a problem with the Ipod Control/Screen of my Z110BT. Following scenario: 1. Avic Z110BT 2. Iphone 3GS 3. Pioneer CD-IU50V (original) When i plug-in the Iphone it detects the Ipod as AV-Source but the Ipod-Screen is completely disabled (including the settings key where I can change the control mode Z110BT<->ipod and vice versa). So i cannot control the ipod through the Z110BT, but the control over the ipod itself works perfectly! The strange thing is that the ipod screen worked all the time! Do you have any ideas about this issue? Quote Link to post Share on other sites
scharnhorst Posted June 13, 2010 Report Share Posted June 13, 2010 forgot where in settings but you can set control for the ipod, whether it be the head unit or the ipod itself. try seeing if this somehow has changed Quote Link to post Share on other sites
VBLUE42 Posted June 13, 2010 Report Share Posted June 13, 2010 Try your cable that came with the iPod to see if it then gives you control from the screen. If it does, you have a defective cable and will need to get it replaced. Where did you buy the iPod cable? Also try a restore of the iPod and re-sync of your content. Quote Link to post Share on other sites
Steve192 Posted June 13, 2010 Author Report Share Posted June 13, 2010 @scharnhorst: I think this setting is available through the settings key in the Ipod screen but this key is also disabled! @VBLUE42: with original cable I have the same result No control from the screen (all keys disabled). I have also checked whether the ipod cable is correctly connected to the Z110BT (all correct so far)! Now I will try to restore the iphone and re-sync my content. Quote Link to post Share on other sites
VBLUE42 Posted June 13, 2010 Report Share Posted June 13, 2010 Try A reset on the unit. Try a different iPod. If you get the same result, you have defective unit. Quote Link to post Share on other sites
dawgbone Posted June 13, 2010 Report Share Posted June 13, 2010 Could it possibly be a regional thing? Taking note of the non-english language on the unit.... Could it be a PAL/NTSC thing? Isn't there a setting in the IPod for this? Just throwing it out there... Quote Link to post Share on other sites
thedak1 Posted June 14, 2010 Report Share Posted June 14, 2010 Is your iphone Jail broke? If so it could be the custom apps that are running on the phone. Quote Link to post Share on other sites
Steve192 Posted June 14, 2010 Author Report Share Posted June 14, 2010 @dawgbone: You are right I have the Avic F10BT, this is the european version of your Z110BT (I'm from germany) I think I've seen such a setting and will check this! @thedak1: No Jailbreak! Ordinary Iphone OS v3.1.3 (7E18) Quote Link to post Share on other sites
Wilcopc1 Posted June 18, 2010 Report Share Posted June 18, 2010 I had that issue with my ipod and fixed it by resetting the ipod. The Z110 hasn't done it since. Quote Link to post Share on other sites
Steve192 Posted June 22, 2010 Author Report Share Posted June 22, 2010 Hello, today I have updated my iphone to iOS 4.0 and now my problem is gone Thank you to everyone! Quote Link to post Share on other sites
stoveken Posted July 1, 2010 Report Share Posted July 1, 2010 there is a setting on avic to control off ipod or navi check it jim Quote Link to post Share on other sites
