chidoc Posted June 23, 2010 Report Share Posted June 23, 2010 OK I have a weird problem when I put the car in reverse the cam does not come on. It was working normally for 2 years. The only way it comes on is if I press the source button and hit backup camera on the screen. When the car is put in reverse it says the input signal is high but the camera does not come on. In the map screen where you can choose view modes the rear cam option is not available. please help? Quote Link to post Share on other sites
chidoc Posted June 24, 2010 Author Report Share Posted June 24, 2010 help anyone? Quote Link to post Share on other sites
jru5822 Posted August 23, 2010 Report Share Posted August 23, 2010 I have same issue?? Quote Link to post Share on other sites
Kaptain Posted August 24, 2010 Report Share Posted August 24, 2010 I would start with checking the wire that senses reverse. I don't recall what type of signal it receives (ground or 12v). If it's not getting either, it's not going to change the screen when you reverse. Just remembered, somewhere in the settings you can also change the way it receives the signal that your vehicle is in reverse. If it was me, I would see if it was set to + or -. Then I could find that wire, remove it and hook a corresponding source. Quote Link to post Share on other sites
ajdillon Posted October 28, 2010 Report Share Posted October 28, 2010 I lost my backup camera while installing the bypass. Had to go to the FM A/V page, select A/V settings, then select system settings and turn the camera back on, it's worth a try. ajdillon Quote Link to post Share on other sites
chrisclang Posted December 20, 2010 Report Share Posted December 20, 2010 I would start with checking the wire that senses reverse. I don't recall what type of signal it receives (ground or 12v). If it's not getting either, it's not going to change the screen when you reverse. Just remembered, somewhere in the settings you can also change the way it receives the signal that your vehicle is in reverse. If it was me, I would see if it was set to + or -. Then I could find that wire, remove it and hook a corresponding source. This worked for me - thanks for the info. Had to get a new battery last night and things with the camera stopped working. Could not remember where those setting were! Chris Quote Link to post Share on other sites
GOLDCYLON Posted February 25, 2011 Report Share Posted February 25, 2011 I would start with checking the wire that senses reverse. I don't recall what type of signal it receives (ground or 12v). If it's not getting either, it's not going to change the screen when you reverse. Just remembered, somewhere in the settings you can also change the way it receives the signal that your vehicle is in reverse. If it was me, I would see if it was set to + or -. Then I could find that wire, remove it and hook a corresponding source. You have to do this everytime you have a battery event as well Quote Link to post Share on other sites
