Reverse Wire and VSS lead for 06 Honda Ridgeline
I've been reading through the forum, lots of information. Great site.
I just wanted to confirm the locations of the reverse and vss wires for my truck. Installing a D2 over the holidays.
Reverse Wire
reverse wire should be green, at the MICU (Multiplex Integrated Control Unit) should be part of the underdash fusebox
VSS Wire
itz blue/white at the PCM (pin 29)
If anyone could verify this for me I would appreciate it.
Also is this the correct picture and process I would use to bypass.
avic-d2_harness_bypass.jpg[/img]
2006 Honda Ridgeline
Reverse Light green + MICU
Notes: The MICU (Multiplex Integrated Control Unit) is part of the underdash fuse/relay box.
Speed Sense blue/white PCM, connector A, pin 29
Notes: The PCM (Powertrain Control Module) is behind the passenger side headlight.
If the stock radio has speedd controlled volume it'll also be in the radio harness a blue wire.
merry xmas
