souji Posted February 9, 2011 Report Share Posted February 9, 2011 So your saying we can put the 2.003 update on after doing the hacked 1.003 2009 update with the CNSD110FM update installed I would like to keep it updated but don't want to brick it. . Followed the guidelines. Just got done doing it here. 1.001 -> CNSD-110FM -> 2.003 I was abit skeptical also but went for it and it works great. Little different getting used to the new UI. Alot easier than expected, the CNSD took about 22 mins, the other 2 were under 5. Whole process was under an hour using 1 SD card and dling the firmwares. I dont see much difference with the maps. My road / house is still wrong, whereas google maps and bing work just fine. Hope this resolves the BT issue. Quote Link to post Share on other sites
skoll Posted February 20, 2011 Report Share Posted February 20, 2011 Just read through the entire thread and most everything worked well here, up to 2.003. However I'm stuck at the BT update at v2.50. With the SD card in the slot(with the Firmware folder at the root), going to the BT screen the Firmware Update icon is disabled. I've tried on 2 different 120BT's and both show that icon grayed out. Quote Link to post Share on other sites
RonS Posted February 20, 2011 Report Share Posted February 20, 2011 Just to clarify, you did the 2.0 update, and then, without first installing BT 3.10 and 3.11, you installed 2.003? Now that is sort of backwards, but I doubt it causes a problem. 2.003 did have some BT fix I recall. Maybe there is some conflict. At least one other member posted that BT Firmware Update was disabled, but I don't recall what the fix was. Maybe that person will see this and jump in here. I do remember once seeing that disabled on my unit, but it was only temporary. I don't remember the circumstances. Maybe you should do a factory reset. Quote Link to post Share on other sites
rublik Posted March 1, 2011 Report Share Posted March 1, 2011 How do i get the au version of the cnsd-110fm? Thanks Quote Link to post Share on other sites
RonS Posted March 1, 2011 Report Share Posted March 1, 2011 How do i get the au version of the cnsd-110fm? Thanks I have no idea, but since you posted the exact same question in 3 threads, I wouldn't say if I did. Quote Link to post Share on other sites
rublik Posted March 3, 2011 Report Share Posted March 3, 2011 I have no idea, but since you posted the exact same question in 3 threads, I wouldn't say if I did. Just trying my luck Quote Link to post Share on other sites
nima Posted March 8, 2011 Report Share Posted March 8, 2011 Hi, I am new in this forum. I just bought an avic-z120bt. i wounder if there is a way to upload navigation maps of different countries. tnx Quote Link to post Share on other sites
RonS Posted March 8, 2011 Report Share Posted March 8, 2011 Hi, I am new in this forum. I just bought an avic-z120bt. i wounder if there is a way to upload navigation maps of different countries. tnx No. If you had a Z110-BT you could theoretically load the EU or AU update to version 2.0 (Z120-BT equivalent) to use maps of Europe or Australia. But not to add arbitrary maps of other countries. Also, I think Pioneer sold an add-on of Mexico for the Z110, but I haven't seen a Z120 version of that add-on. You didn't say which countries you wanted. Helps if you give more details - you might get more specific answers. Quote Link to post Share on other sites
rublik Posted March 15, 2011 Report Share Posted March 15, 2011 Anybody can help with the AU maps (need the CNSD-110FM version of au) Quote Link to post Share on other sites
Samwell Posted March 25, 2011 Report Share Posted March 25, 2011 Hi, sorry for my english: the ulocker works with eu F10??? the istructions for load cnsd 110 fm are the same for F10?? Anyone did it on F10 yet? thanks Quote Link to post Share on other sites
aupacrivi Posted April 4, 2011 Report Share Posted April 4, 2011 Pandora source only shows up when you plug in the iPhone/Touch. Hello!! I´ve the f20bt, with the 2.003 version updated from factory. I´m tryin to connect the iphone to the navigator but pandora link doesn´t appear (i´ve installed in my iphone the pandora link aplication). Do you know if there is any way to liberate this option in the european f20bt. I´ve compared the two firmwares (z120 and f20) and it seems they are exactly the same.... Has anybody found any kind of hidden menu as an other pioneer devices have?? Thank you very much Quote Link to post Share on other sites
Black Patriot Posted April 10, 2011 Report Share Posted April 10, 2011 Hi, having read though the entire thread I've got to say, great work people, this truly is impressive. Following that I do have a question, I live in Australia, and the local AV market is very overpriced. If I were to buy a Z110BT from the US and update it with the firmware for the Australian F20BT, would that get me Australian navigation? I don't care about using the radio or the DVD player (do region free disks work?) since I have my iPhone loaded with all my music. Thanks Quote Link to post Share on other sites
echeunga Posted April 13, 2011 Report Share Posted April 13, 2011 Well... I recently moved to Finland from Canada and shipped my car over (which had the Z110BT installed). So, I took a chance and tried the upgrade to the EU maps. After reading the entire thread, it doesn't seem like anyone has done z110BT -> F20BT. All that was attempted was F10BT -> the z110BT hack -> F20BT. So, here's what I had to do: 1.) Installed the ShortFuse Hack (This went smoothly - Thanks Shortfuse!) 2.) Then I inserted the EU Version of CNSD-110FM SD1 - So this didn't work. Inserting the SD Card did nothing 3.) Downloaded the US version of CNSD-110FM SD1 and inserted it into the unit - This worked. It prompted me the message. So, I chose not to continue 4.) I copied the US version of CARDINFO.cif onto the SD Card of the EU Version of CNSD-110FM SD1 and replaced the EU version. 5.) I inserted this SD card into the unit and it worked! I can confirm that my z110BT now has the F20BT Software and Maps. I get the new UI and I have the EU maps. But... there are a few drawbacks. - Navigation does NOT work (You can't search for the address, can't search for POI's, it just gets stuck at the loading screen, etc) - If you try to arbitrarily pick a spot on the map and select to Navigate there, it kind of works, but you don't get Voice Guidance. - The regional settings are still for US and Canada, so I can't set my clock to the correct time. The most I can do is +9 hours which is 1 hour off from Finland time zone. Other than that, everything seems to be working. Quote Link to post Share on other sites
Drin Posted April 15, 2011 Report Share Posted April 15, 2011 2.) Then I inserted the EU Version of CNSD-110FM SD1 Where did you find European Version of CNSD-110FM? Quote Link to post Share on other sites
echeunga Posted April 16, 2011 Report Share Posted April 16, 2011 There's another thread in this forum where they mention the EU version can be found. So I checked it out and it was there: http://www.digital-eliteboard.com/ Quote Link to post Share on other sites
Join the conversation
