paQ Posted October 2, 2010 Report Share Posted October 2, 2010 Can someone please clearify where to find and how to edit the roadsigns on highway navigation? Standard scheme all signs are dark green, but that is not how they look in (W) Europe. Did a whole bunch of searching and looking in the ini files my self, without any succes so far. thanks Quote Link to post Share on other sites
abb1 Posted October 3, 2010 Report Share Posted October 3, 2010 They are found in 'DATA\ui_pioneer\common\laneinfo_signpost.ini'. Open it with notepad and in there you can change the color of the signposts in RGB format as well as the size of the text on the sign boards Quote Link to post Share on other sites
paQ Posted October 3, 2010 Author Report Share Posted October 3, 2010 thanks Quote Link to post Share on other sites
paQ Posted October 4, 2010 Author Report Share Posted October 4, 2010 uhm... ;This file is obsolete, every resolution directory should contain a customised copy of it arrow="$lane_vsimp_sel_signpost.spr" arrow_mode=2 arrow_sel="$lane_vsimp_sel_signpost.spr" ;bg="$lane_bg.spr" bg_mode=0 div="$lane_div.spr" div_mode=0 max_lanes=11 min_lanes=2 only_at_maneuver=2 skip_opposite=1 connectivity_mode=0 one_signpost_mode=0 signpost_bg="$signpost_template_bg.bmp" signpost_border="$signpost_template_border.bmp" signpost_fade="$signpost_template_fade.bmp" signpost_bottom_padding=4 signpost_top_padding=8 signpost_left_padding=8 signpost_right_padding=8 signpost_arrow_padding=2 signpost_word_padding=5 signpost_line_padding=0 signpost_max_lines=3 signpost_font_size=24 signpost_pictograms="$signpost_pictograms.spr" valid_var="bLaneinfoSignpostValid" signpost_background_color=RGB(0,48,32) signpost_use_road_name_if_empty=1 signpost_separate_destinations=1 obsolete!? these bmp files which this code refers to, I'm unable to open them. edit: I've replaced all singpost bmp's and spr's with IDT 3 version. Layout has changed a bit, but the signs remain dark green instead of blue Quote Link to post Share on other sites
BorisM Posted October 4, 2010 Report Share Posted October 4, 2010 uhm...edit:I've replaced all singpost bmp's and spr's with IDT 3 version. Layout has changed a bit, but the signs remain dark green instead of blue signpost_background_color=RGB(0,48,32) This is the line you want to edit. In proper iGO distribution, there'd be an individual file for every resolutiuon, but for AVIC a common one works, since AVIC has a fixed resolution anyway. Quote Link to post Share on other sites
abb1 Posted October 5, 2010 Report Share Posted October 5, 2010 Exactly! Change it to this color signpost_background_color=RGB(32,40,96) Quote Link to post Share on other sites
