ugadawgs311 Posted December 10, 2010 Report Share Posted December 10, 2010 What are some good/reasonable prices you would pay to have a professional install a X920BT? I have a 2007 Tahoe, and it has Bose, Onstar, rear entertainment, etc., so I imagine my install might cost a bit more than the average. Anyways, I've had a place offer to do it for $150; is that a good price? Thanks! Quote Link to post Share on other sites
1loudls Posted December 13, 2010 Report Share Posted December 13, 2010 my shop would charge you just for the nav parts: dash kit-$22 wire harness-$150 (scosche GM21SR) antenna adapter-$13 Labor: mobile video/ nav install-$100 if you have steering wheel controls parts: Swi-ps-$100 labor: steering wheel adapter install-$60 intergrating with the factory DVD player to get video from avic to show up on rear screen parts: RCA cables-$30 labor: running RCA cables and soldering wires to AV board (if no aux in plugs or dont want cable showing being plugged into aux in)-$40 intergrating with the factory DVD player to get rear dvd image to show on avic screen in front parts: RCA cables-$30 labor: running RCA cables and soldering wires to AV board (if no aux in plugs or dont want cable showing being plugged into aux in)-$40 PARTS TOTAL - $345 TAX TOTAL - $20.70 LABOR TOTAL - $240 GRAND TOTAL - $605.70 so if you are really going to be able to get all of this done for $150, i would jump on it only after making sure that they know whats going to be needed to make it work with the bose system (as that part alone is $150) and that they do good enough work to where they are not going to destroy your car. it just seems to good to be true. Quote Link to post Share on other sites
ugadawgs311 Posted December 13, 2010 Author Report Share Posted December 13, 2010 Well it turns out that the guy who quoted me the price of $150 got fired a few days later...apparently he had no idea what he was talking about. I was since offered a price of $278. I have already purchased all the necesary products needed for the install (wiring harness, installation kit, steering wheel controls, etc.) so they are charging me just for the install, no products. I installed a D3 in my old 2004 tahoe so I have some experience, but if I can save 8 hours of frustration, cutting, wiring, splicing, crimping, etc. for $278, maybe that's worth it. Quote Link to post Share on other sites
1loudls Posted December 13, 2010 Report Share Posted December 13, 2010 yea $280 for labor only isnt too bad, onstar/bose interfaces and steering wheel controls can be a little tricky if you are not used to doing them. and you might need some wiring schematics while interfacing with the factory DVD player. Quote Link to post Share on other sites
wildfxp Posted December 18, 2010 Report Share Posted December 18, 2010 I just got my unit installed and the places around here is charging $100-150 with the harness and kit for the dash area (for a perfect fit). Luckily my dad has a friend that does audio stuff, so I got the unit installed for $60, but I decided to get brand new speakers (components) and an amp as well. Total was $170 and all I provided was the head unit, speakers, and amp. Dash kit is usually around $20-30 and the wiring harness is usually $7-10 Quote Link to post Share on other sites
1loudls Posted December 20, 2010 Report Share Posted December 20, 2010 the wiring harness is usually $7-10 not for his car, the wire harness has a computer module that decodes the signals from the data bus line (when to turn on & off, dimming. reverse, VSS, and p-brake) and converts the signal to what the factory digital amp need to see, it also intergrates the factory OnStar so that it still works, and it cost quite a pretty penny Quote Link to post Share on other sites
wildfxp Posted December 20, 2010 Report Share Posted December 20, 2010 not for his car, the wire harness has a computer module that decodes the signals from the data bus line (when to turn on & off, dimming. reverse, VSS, and p-brake) and converts the signal to what the factory digital amp need to see, it also intergrates the factory OnStar so that it still works, and it cost quite a pretty penny Oooohh I got it, my bad! Quote Link to post Share on other sites
