aaronmp2315 Posted January 27, 2011 Report Share Posted January 27, 2011 is it okay to use the radio antenna signal wire instead of the remote control wire to send signal to the amp? if yes should i put the radio antenna to power mode? tnx by d way i have avic d3 Quote Link to post Share on other sites
JasonH Posted January 27, 2011 Report Share Posted January 27, 2011 Should be ok as long as it's in power mode. Quote Link to post Share on other sites
aaronmp2315 Posted January 27, 2011 Author Report Share Posted January 27, 2011 Should be ok as long as it's in power mode. tnx just worried that i may fry my amp. do they have the same voltage output? Quote Link to post Share on other sites
JasonH Posted January 27, 2011 Report Share Posted January 27, 2011 Yeah they're both 12v. Quote Link to post Share on other sites
aaronmp2315 Posted January 27, 2011 Author Report Share Posted January 27, 2011 Yeah they're both 12v. tnx. jusg dont want to remove the unit again and swithc the wires Quote Link to post Share on other sites
aaronmp2315 Posted January 28, 2011 Author Report Share Posted January 28, 2011 Yeah they're both 12v. I did connect the radio antenna wire to the remote signal of my Infinity Basslink. The Basslink is always on even if my D3 is off. So whenever the car is on my basslink is also on. Is this normal with the D3. I have the same thing on my other car but my HU is a pioneer m80bt and the basslink only turns on when the HU is on. Any insights will help...tnx... Quote Link to post Share on other sites
1loudls Posted February 4, 2011 Report Share Posted February 4, 2011 yes all AVIC's keep their amp wires and ant wires (if set to power)powered up any time the unit has power because they dont fully shut off when you turn it off, just the audio side shuts off. (that way, if you have a route planed it can still give directions with the radio being off) Quote Link to post Share on other sites
