fcapizzo Posted January 6, 2007 Report Share Posted January 6, 2007 I've had my Z1 installed for almost a week now in my 2001 Infiniti I30. When I went to pick up the car and was going over all the functions with the installer, I pointed out how the audio sounded so weak. He commented that I just needed to spend some time tweaking the equalizer and other sound settings. And so I have been messing around with equalizer, sound staging, HPC, Loudness, Source Level, and Bass settings just about every day. No matter what I do, it does not sound right. First of all, pushing the volume at 34 and up will cause distortions, then the bass just sounds all garbled, not powerful or deep like I remembered with the Infiniti's stock head unit. FYI, the original Bose speakers from the car are being used. What can I do to make the audio sound any better? Do I need to get more information from the installer? Quote Link to post Share on other sites
cntrylvr79 Posted January 6, 2007 Report Share Posted January 6, 2007 How did the installer integrate the bose system? Depending on how it was done, that can and will cause the problem you're having. By the way your best option would be complete removal of the bose system if you can spare the dough. Quote Link to post Share on other sites
tillithz Posted January 6, 2007 Report Share Posted January 6, 2007 is there a sub, if so was it used? Quote Link to post Share on other sites
fcapizzo Posted January 6, 2007 Author Report Share Posted January 6, 2007 cntrylvr79, you'll have to pardon my ignorance, but why would my best option be to remove the Bose speakers? Those speakers sounded great with the factory system, so why shouldn't they sound great with the Z1? Is there anything I can have my installer check to work on it? Quote Link to post Share on other sites
tillithz Posted January 6, 2007 Report Share Posted January 6, 2007 because the impedance may and probably isnt matched for a standard aftermarket head unit. they can over heat or cause time shift issues if running different impedance levels. Thats why typically you would try to use the amp(s) to run them with an aftermarket head unit Quote Link to post Share on other sites
fcapizzo Posted January 6, 2007 Author Report Share Posted January 6, 2007 tillithz, thanks for your explanation, even if it was somewhat over my head . Let me ask this a different way: How can I get good sound using the Z1 without replacing my existing speakers? Quote Link to post Share on other sites
tillithz Posted January 6, 2007 Report Share Posted January 6, 2007 find out what was done now.. then you can go from there. Quote Link to post Share on other sites
parm104 Posted March 31, 2007 Report Share Posted March 31, 2007 i know this thread is about a month or two old but if you haven't removed your bose speakers yet, then good, DON'T DO IT. The other user stated that you should be running your bose speakers through and independant amplifier...chances are, you're bose speakers are already running off the BOSE amplifier. So you're good. Just fine tune your settings on the deck and they will sound great. I've got a 12 speaker setup plus 2 self-powered subs for my A4. They sound even better now with the D1 than they did with the Bose Symphony II head unit. Quote Link to post Share on other sites
