roadkingdoc Posted January 7, 2007 Report Share Posted January 7, 2007 i want to bypass a d2 in my h3. the installer said it wasnt possible to do it. i would like to know how to remove the dash bezel. thanks roadkingdoc Quote Link to post Share on other sites
roopstar Posted January 7, 2007 Report Share Posted January 7, 2007 i can do it but ur gonna have to com to vancouver Quote Link to post Share on other sites
roadkingdoc Posted January 7, 2007 Author Report Share Posted January 7, 2007 be there in about 1hr! Quote Link to post Share on other sites
H3blue Posted January 7, 2007 Report Share Posted January 7, 2007 The radio surround just pops out, with the AC vents above it and all of the controls attached. Put your fingers in the lighter sockets and pull, then work your way around. Six clips I believe. Put the shifter in D1 to give you more room. Then you'll need to unhook all of the connectors on the back, only tricky one is on 4WD controls. It has a green tab that pulls out, then squeeze the connector (from bottom to top) and pull to remove. It really is pretty easy, I've been into mine quite a bit to install my D2. Quote Link to post Share on other sites
wpageabc Posted January 9, 2007 Report Share Posted January 9, 2007 The radio surround just pops out, with the AC vents above it and all of the controls attached. Put your fingers in the lighter sockets and pull, then work your way around. Six clips I believe. Put the shifter in D1 to give you more room. Then you'll need to unhook all of the connectors on the back, only tricky one is on 4WD controls. It has a green tab that pulls out, then squeeze the connector (from bottom to top) and pull to remove. It really is pretty easy, I've been into mine quite a bit to install my D2. I agree. Added to this using a plastic stick or a orange stick to pry the top will help the retaining clips to release this surround... Quote Link to post Share on other sites
