js117 Posted February 12, 2007 Author Report Share Posted February 12, 2007 Yes it should. You mean you didn't connect the ground from the z1 to anything, or you didn't use the ground in the metra harness. You have power and switched at the z1 harness. I did not connect the ground from the metra harness yet. I connected all of the other wires in the harness that apply. I do have power to the harness when I checked so it should be sending juice to the Z1. Quote Link to post Share on other sites
cntrylvr79 Posted February 12, 2007 Report Share Posted February 12, 2007 Ok is the ground wire of the z1 connected to anything? Quote Link to post Share on other sites
js117 Posted February 12, 2007 Author Report Share Posted February 12, 2007 Yes, now it is, I had a bad ground so I extended it to a place on the truck I had a good connection. From the Great Carlos Mencia I was a Dee Dee Dee on this one. After I grounded it I was able to power it right up, yet I still can't find that parking brake assembly wire. One last question, will I have to now engage my parking/emergency brake every time I want to set the Nav, this seems like a pain. Quote Link to post Share on other sites
cntrylvr79 Posted February 12, 2007 Report Share Posted February 12, 2007 Yeah pretty much. You're other option would be to do the bypass. Depending on the manufacture date of the z1 will tell which method you use. go here for the bypass info. www.sminntech.com/z1flash.html Quote Link to post Share on other sites
js117 Posted February 12, 2007 Author Report Share Posted February 12, 2007 December 2006 model, also that link wasn't working. Thank You for all of your help Quote Link to post Share on other sites
cntrylvr79 Posted February 13, 2007 Report Share Posted February 13, 2007 sorry forgot the extension. Link works now. Quote Link to post Share on other sites
Join the conversation
